hi guys.
my front wipers are not working (rear are working though) and i cant find a fuse for them. ive only managed to find a wiper amp box on the drivers side rear corner of the engine bay. ive taken my steering colum covers off near the wiper arm and the switchs are ok and have good ground(earth) supply but no power supply to the switch.
can anyone surgest anything else to check before i go to the auto elecs?
thanks
Justin
https://www.sau.com.au/forums/topic/217617-please-help-wipers-not-wrorking/
check the fuse pannel down beside the accelerator pedal
here's most of the translation!
R34_GTT___Fuse_panel___Jap_to_Eng.pdf
that was the first fuse panel i checked. all the fuses where ok. but ill check again now that i know the translation.
thanks.
    • Crazy how good the aero bar looks compared to the stock one
    • Yes, but you will need to rewire all the things that are different. CAS, coils, etc. Yes, but there is no IAT. What? You can use anything you like. It just has to be hooked up so that it will work.     Or are you wanting to just plug and play without having to do any thinking/work?
    • It's been a little over a decade since I bought the S15. As I did on my socials, I'll share some of my favorite pictures from over the years further below. If you haven't realised, pretty much all the pictures in my posts are ones I've taken.  In terms of updates, I don't have pictures, but I acquired a near-perfect pair of fog lights from a friend of mine, so those got swapped in for the pair I already had. As for the JZX110, I just got it back from being fixed. A few weeks back, I was on the highway when I suddenly drove over something with very little time to react. It was probably the size of a soccer ball, but it went under the car and banged into the underside pretty loudly. I pulled over and realized the fluid leaking was fuel, and of course, it was right near my exhaust. This required replacing the fuel tank. If you happen to be in the same predicament, thankfully this car shares a fuel tank with the JZS171, IS200, and IS300, so it wasn't too painful to replace. Enjoy some pictures as mentioned above, including the carnage from the fuel tank and a bonus picture I came across which shows how ridiculously shiny the Bugels are on the 110. So many more pictures I could share of the S15 but this will do for today, enjoy.
    • Welcome.  Was the mistake the car, or joining us? 馃槒
    • Yeap, was me and the daughter getting coffee before heading to the new joint to measure up the fridge space and taking some pics that the solar installer wanted of the switch board
