023 same pump as the 044 but with the open end (like 040). 044 may be an external pump in the catalogue but i think this relates to the fitting on the bottom. plenty of them mounted in tank out there.
still more work to install than a nismo
so either quick easy install vs slightly more fiddly (+ higher labour cost)
Edited by wolverine
https://www.sau.com.au/forums/topic/217618-which-fuel-pump/#findComment-3847674
and if your going the in tank version then you want the 040, 044 is the external version.
actually the 023 is the intank version of the 044. the 040 flows less.
Takes about 20mins end to end to install a bosch, i remember doing it one night with a torch.
if you can modify the bracket by bending or cutting the factory metal pipes, locate the 044 the correct height on the bracket, install a sock on the bottom (additional parts), rotate the clamps on the bracket until they don't fowl inside the tank in under 20 mins you have done well. most workshops will hit you up for more than 20mins but i agree it can be done (like most things with familiarity). the 023 won't need the sock and should mount lower on the bracket and should be less likely to fowl inside the tank.
the nismo one is definitely quicker since you just swap brackets.
i reckon most people spend more than 20mins trying to get that bloody black ring threaded properly. :P
any of these pumps will be a good thing.
https://www.sau.com.au/forums/topic/217618-which-fuel-pump/#findComment-3848113
have fun mounting a difficult, noisy external pump to the inside of your fuel tank..
stop talking shit jono.
far from a hard or complex procedure.
and you may be suprised to here how quiet this setup actually is.
you can here it prime and that is all, never to be heard again.
its all about rubber mounting it properly as seen in the pic.
i classed it as a very easy install and i had no one to copy off.
now that i have given a pic of the finished install, it aint hard to copy,
and i would agree with nismoid by saying 20 min job.
044 around $210 - $230
fuel sock $30
fittings, stainless clamps, clear fuel hose and high flow non return valve from pirtek $40.
total shoping time 1 hr
total install time for a average bloke 20 - 30 min.
less then $300 all finished
with far greater hp potential.
https://www.sau.com.au/forums/topic/217618-which-fuel-pump/#findComment-3849588
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
    • The fact that US/JDM plates actually fit the skyline bumpers properly is a big, big thing for me as they are the correct dimensions. Annoyingly you can't opt for a normal plate (or plate combination) in that size. You have to make up your own one, and at that point you'd still know it wasn't randomly assigned.
    • Well, really, that's any ECU, because it's not so much the ECU that the tuner connects to, but a laptop that's connected to the ECU. You have to have the tuning software installed locally. The "remote" part is essentially just remote desktop (RDP) or VNC type access. Nevertheless, if you're looking to upgrade, then you're immediately in the Haltech/Link territory, both of which can be done by any number of competent tuners here in Oz. But without a dyno, you'll definitely also need a wideband O2 sensor fitted, and you'll probably be relying on "auto" tuning a bit, where you drive it around under various loads and then apply the corrections that the ECU learns (basically applying the fuel trims that the ECU has to do to correct the mixtures). Tuning the timing is a little harder. It can be difficult to trust the old OEM knock sensors on RBs, so it is definitely best to have someone who knows what they're listening for, with knock ears (a piezo microphone connected to the engine, and and little amp and headphones so the listener can hear the angry men with hammers who live in the engine). That is more difficult to do remotely, and I suspect the only sane way is to be quite conservative on timing. But that's OK. You're probably waaaaay better off with conservative timing where you are. What is the fuel situation? 98RON available? Or low grade jungle juice?
    • I see your point, I didn't think too deep into it, was purely focused on the price. There's no bad blood between myself and GSM, they acknowledged the price was cheaper else where and at the time couldn't match it.
