Hi. i have a R34 25GT-T with a GT30R with stock internals, i was wondering if it would be necesary to have a oil catch can with this setup or when is that you really need one in a rb25.
Im not planing to go over 20psi or over 7500 rpm
thanks
Giancarlo
https://www.sau.com.au/forums/topic/217628-catch-can-question/
A catch can always a good idea.
At taht level of boost if you are hitting redline and pedalling the throttle a lot you will begin to get blow by issues. A catch can will collect the oil vapour/mist that comes out of the roker cover breathers when you get off the throttle after full boost.
when you say blown by issues you mean oil coming out issues or other type of issues?
Yeah blow by is gases from combustion squeezing past the piston rings or past a cracked piston or ringland and pressurising the sump. This will cause oil to be sucked into your turbo if your oil breathers are connected to your intake (factory setup). If you start getting alot of blow by, oil will begin to leak out of the BOV if you have an aftermarket one and out the oil filter and possibly the dipstick.
Basically just hook up a catch can to stop any oil vapour from being re-circulated through your intake system.
Ok in a catch can reconected to the block, everytime i lift the gas the vacum will suck all the oil back to the engine preventing any leak or blowing?
From my understanding of a catch can, its to catch all the oil fumes so it does not go into the air intake.
Then you gota empty it out and all this yuck claggy shit come out of the can.
And I think you might have to do a bit more of a regular oil top up.
I had one but the previous owner did not pipe it correctly and had a hose from the catch can leading out to the atmosphre and oil was basicaly evaporating out.
Unless for race applications, I don't think you need it.
So it allows your engine to 'breath', sorta...
If it's installed correctly, it's actually an oil-air separator. As the oil-vapour laden air passes into the canister, the oil condenses out, leaving just "clean" air to continue on to the induction side.
Cool thanks!
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
