Hi guys,
Just thought I might share my video with ya'll. Went for a drive this morning (nice and cold), got up to about 200km/h.
Have alot of traction issues in 1st and 2nd gear, sometimes even third if you smash the gears in.
What do you guys think, not bad acceleration?
cheers
https://www.sau.com.au/forums/topic/217630-hks-gt2835-pro-s-turbo-2723-rwkw/
  • Replies 50
Nice man, I assume that was all done on a closed runway :cheers:
270 odd kw is my eventual power aim, if you don't mind me asking how much was the 2835 and what other mods do you have? How much boost you running? I was originally wanting a GT-RS but from everything I have seen it will struggle to net 270+ without cams or excessive boost.
Hey mate, don't mind you asking at all.
The turbo was about $3,250 delivered to Canberra, Australia. I paid a little more as I wanted to pay with paypal (ALWAYS PAY WITH PAYPAL when buying things from overseas!!!.
Running about 17-18PSI (It fluctuates depending on the weather)
I got the normal mods; 555cc Nismo Injectors, Bocsh 040 fuel pump, GReddy front mount, Splitfire coilpacks, straight through exhaust, power FC, Cold air intake with heat shield, and the HKS GT2835 turbo with the HKS split dump pipe.
The turbo is ALOT laggier than stock, but yes MUCH MUCH tougher!
Personally, I don't think its worth it compared to the GT-RS, if I had a second chance, I would've gone for the GT-RS, purely because of the money factor. But then again, you do get the split dump with the 2835 turbo kit.....
Nonetheless, both are great turbos!
Cheers
I have 314rwkw and its not that much quciker than what you have recorded, well done.
haha, yeah, you were on a private runway
Cheers mate.
Yeah, ofcourse I was on a closed runway! :cheers:
Mafia, when you achieved your 12.4 1/4 mile time, what was your 0-60 time? I thought with 314rwkw you should be in the VERY low 12's, maybe even break into the high 11s?
Edited by Turbz RB-25
hey mate, the power was down a lot when I ran that time, as I just installed a new fuel pump and the AFR's were at 10:1 lol.
Not sure what it runs now with the new power, as the track is not finished. It was destroyed in the floods we had recently.
Be interestingf you could run a wheel speed sensor off a front wheel that way the loss of traction doesnt mess with your speedo.
Looks grunty, only, why post footage of you doing crazy speeds in a public place like youtube then link it on a public forum ;)
Because it was done on private property and I would like to see you or the police prove otherwise :happy:
Perhaps he was indicating to other cars he was entering pits?
Look we know he did it on a public road but the point is he filmed ONLY the instrument cluster and at no point did he say it was done on a public road. Innocent until proven guilty and there is nothing conclusive for the cops to go on. Lets just apreciate the video for what it is, which is someone with a new turbo showing us what its like :happy:
Thats interesting... The 2835 is usually considered to be a relatively lag free turbo...
I'm not saying that the turbo is a lag monster, but compared to the stock turbo (especially when I first got in the car after the dyno tune), it was sooooo much laggier than the stock turbo... But when it hits, it's nothing but smiles! :nyaanyaa:
Thanks for all the comments guys.
VERY nice turbo (HKS GT2835 Pro S) indeed.
cheers
Very nice video :( Was interesting to observe, I can't tell watching it if my turbo (.82a/r GT3076R) is any laggier - nothing obvious thats for sure . Something else which is interesting is your car is definitely a bit quicker than mine, I have made very similar power number but on a hub dyno so all it does is confirms what every already knows - hub dynos read a bit higher haha. When I sort a couple of things out I am tempted to try a 17-18psi tune and have a blat at the local race track (I actually have one 15mins drive from my house!! :( ) and see what mine does the rolling to 200k thing like.
Should be good for some rapid 1/4 mile times like that, especially with some sticky tires.
    • Hi again all, I’ve tried doing some searching on the topic but couldn’t find the answer I’m looking for.   I deleted my clutch booster because it had an air leak and was squealing like a hog, and now my clutch has very poor pedal feel and the friction zone is way too small, so I believe I need a bigger diameter clutch master cylinder to compensate for not using the booster. I found a Wilwood option that’s 3/4” for a good price and will fit my 3AN clutch line, but all the firewall adapters I see online such as RB factory or Chase Bays are listed as RWD only (GTST/GTS). Link below. https://rbfactory.shop/products/nissan-to-wilwood-girling-clutch-master-cylinder-adapter My question is if these adapters will also fit a GTR, and if anyone has experience using a 3/4” CMC without the booster, my clutch is a Nismo coppermix twin plate.   Thanks, always appreciate the advice!
    • Catching up on a post, I've replaced the external shark fin with a small 4g antenna (no further drilling, just a 1mm embiggening of the existing hole, and run that to where the dual battery models have the battery in the left rear guard.  No idea what the factory antenna did, but removing it had no impact on anything I use, according to the US manual the GPS antenna is in the dash and it still works fine Also ended up stealing battery power from one of the amps and ACC power from a unit nearby to add an ACC relay to power it. The mounted the booster, wifi, power socket and antenna splitter in the rear left guard out of the way, all out of site with the boot trims in
    • What drama? The only drama you're going to have is the near constant work to maintain all those sphericals. I only have sphericals in my front caster rods and front upper CAs (because both of these are near compulsory in an R32). I have had the front arms out of my car 34 times already this month, and if the new replacements arrive today, I will have them out and apart again tomorrow. Chasing clicking and clunking that comes from sphericals being a.....poor choice for a road car. Moisture and dirt are not their friends. I have been contemplating a change to my rear subframe that would require me to use sphericals in my lower CAs. And.....I don't want to have them that close to the road.
    • Did you need anything else you've already done? If you had it before... and liked the changes after, then supposedly it'd be more of the same. The idea about most suspension arms is to tune geometry that the OEM arms max out at/can't handle because they weren't designed to have the car setup in such a way that 'looks good'.
    • I have replaced everything on my r34 including suspension to Miester R, all rear subframe bushes to poly, all arms to metal adjustable and same in front.   only thing I haven't touched is the front lower control arm. Should I? what improvement can i expect ? I mean the one on the link below?   Car drives perfectly, it is just me thinking everything is either puly bush or hard bearing type so should also do lower control arm front but do I really need it ? https://www.japspeed.co.uk/product/suspension/adjustable-arms/nissan-200sx-s13-s14-s15-skyline-r32-r33-r34-adjustable-suspension-front-lower-control-arms/?gad_source=1&gclid=Cj0KCQiAo5u6BhDJARIsAAVoDWs5V_PauQPf0kx3zFCaA4tOC9Q7JSIsfJWma_jAPN2f1sJA686djOwaAidgEALw_wcB
