Any info you can give us on the camera setup? Is it a lipstick camera inputted to a digi cam? I have been looking for a setup for track days, scrutineers are getting pretty strict with installs these days so if you can get that quality out of a lipstick camera i would love to hear about it
  • Replies 50
I don't know what a 'lip stick' camera is, forgive my ignorance.
Nonetheless, the camera I used was just an ordinary still shot camera in video mode. I merely wrapped cloth tape (VERY sticky sticky tape) around the camera and steering column to ensure it doesn't move around, simple as that.
Cheers.
in a nutshell:
the gtrs is a re badged garet 2871 series housing
the 2835 pro s is a re badged garret 3071... i.e. bigger
the gtrs lines up with the stock dump pipe
2835 needs a custom job, or if bought in a kit comes with its own dump pipe.
the 2835 will net you 30rwkw odd more for roughly 1k more
BUT... its been said on here a few times that the gtrs is for those who want to fry every gear and the 2835 is for those that want to be able to get their power to the ground.
both fun options... i went for the 2835.... (still waiting to install it tho) :D
Thats interesting... The 2835 is usually considered to be a relatively lag free turbo...
i have the HKS 2835 PRO S on my rb20, only just put it on an still have to get it tuned but dam, makes 3 psi at 3k lol full boost at around 4.5k, its slow but has a bit of kick at the end, nothing like the
vid, very impressive mate
nice setup !!! money well spent if you ask me.
i found a guy who has a hks gtrs turbo on you tube if any one is interested in see it..
post the link dude :P
edit: http://www.youtube.com/profile_videos?user=r33Niko
Edited by Munkyb0y
in regards to the above you tube links.
im not real sure what you guys see in the gtrs.
have you not been in anything faster?
it makes lots of wooshing noises but dosent seem to pull very hard.
you may say im full of shit but i know what my wifes car is capable of and that gtrs has nothing on the muppet bus.
i think the car above in question has lots of mods and a hell of a lot of money thrown at it , yet it struggles to make the wheels chirp as it ramps onto boost in second. wheres all the midrange? for dollars spent it should spin to the limiter when you floor it in second, but it dosent.
Yeah thats a fairly good point, if thats in 2rd - mine gets a lot more savage than that and romps through second. Makes the pretty noises too, but probably a fair bit cheaper setup - and only running conservative boost.
The GT2835 vid posted in this thread sounds like it'd give it a spank :thumbsup:
Heres a clip with mine when I got the internally gated housing, before I got the boost controller for it:
http://www.youtube.com/watch?v=1tajFNv_q7Y
    • Hi again all, I’ve tried doing some searching on the topic but couldn’t find the answer I’m looking for.   I deleted my clutch booster because it had an air leak and was squealing like a hog, and now my clutch has very poor pedal feel and the friction zone is way too small, so I believe I need a bigger diameter clutch master cylinder to compensate for not using the booster. I found a Wilwood option that’s 3/4” for a good price and will fit my 3AN clutch line, but all the firewall adapters I see online such as RB factory or Chase Bays are listed as RWD only (GTST/GTS). Link below. https://rbfactory.shop/products/nissan-to-wilwood-girling-clutch-master-cylinder-adapter My question is if these adapters will also fit a GTR, and if anyone has experience using a 3/4” CMC without the booster, my clutch is a Nismo coppermix twin plate.   Thanks, always appreciate the advice!
    • Catching up on a post, I've replaced the external shark fin with a small 4g antenna (no further drilling, just a 1mm embiggening of the existing hole, and run that to where the dual battery models have the battery in the left rear guard.  No idea what the factory antenna did, but removing it had no impact on anything I use, according to the US manual the GPS antenna is in the dash and it still works fine Also ended up stealing battery power from one of the amps and ACC power from a unit nearby to add an ACC relay to power it. The mounted the booster, wifi, power socket and antenna splitter in the rear left guard out of the way, all out of site with the boot trims in
    • What drama? The only drama you're going to have is the near constant work to maintain all those sphericals. I only have sphericals in my front caster rods and front upper CAs (because both of these are near compulsory in an R32). I have had the front arms out of my car 34 times already this month, and if the new replacements arrive today, I will have them out and apart again tomorrow. Chasing clicking and clunking that comes from sphericals being a.....poor choice for a road car. Moisture and dirt are not their friends. I have been contemplating a change to my rear subframe that would require me to use sphericals in my lower CAs. And.....I don't want to have them that close to the road.
    • Did you need anything else you've already done? If you had it before... and liked the changes after, then supposedly it'd be more of the same. The idea about most suspension arms is to tune geometry that the OEM arms max out at/can't handle because they weren't designed to have the car setup in such a way that 'looks good'.
    • I have replaced everything on my r34 including suspension to Miester R, all rear subframe bushes to poly, all arms to metal adjustable and same in front.   only thing I haven't touched is the front lower control arm. Should I? what improvement can i expect ? I mean the one on the link below?   Car drives perfectly, it is just me thinking everything is either puly bush or hard bearing type so should also do lower control arm front but do I really need it ? https://www.japspeed.co.uk/product/suspension/adjustable-arms/nissan-200sx-s13-s14-s15-skyline-r32-r33-r34-adjustable-suspension-front-lower-control-arms/?gad_source=1&gclid=Cj0KCQiAo5u6BhDJARIsAAVoDWs5V_PauQPf0kx3zFCaA4tOC9Q7JSIsfJWma_jAPN2f1sJA686djOwaAidgEALw_wcB
