hi guys,
i just need some help setting up my car. recently i have spun a bearing on my r33 gtr its almost finished being rebuilt and i dont know how much boost i can run and what power i could be getting???
Mods
• Full engine rebuild blue printed bottom end
• ACL race bearings big end and main
• Aries forged pistons 1mm oversize block deck/milled/bored and honed
• Eagle forged rods
• ARP head stud kit
• 2 x HKS 2530 turbos
• N1 oil pump
• MLS 5 layer steel gasket
• Recondition head
• Ported exhaust manifold
• Custom twin dump pipes
• HKS super dragger exhaust
• Microtech computer
• Trust twin entry intercooler
So can anyone tell me what boost i should run and what power i could be getting im looking at about 320+RWKW
https://www.sau.com.au/forums/topic/217635-rb26-rebuilt/
You don't mention what you have for a fuel system.
With your mods you can pretty well go where you like if you can get sufficient fuel and a clutch that will hold up.
Have a scan through the RB26 mods list and you will get a good idea but for ~320 rwkw you will probably need bigger injectors and a bigger fuel pump and run anywhere from 1 to 1.4 bar to get your target depending on who is tuning it.
https://www.sau.com.au/forums/topic/217635-rb26-rebuilt/#findComment-3841305
^^^ cheers
how long can the motor hold 25psi for, will it blow up??
not if i built it...hehe
my last engine with 2530's saw 34psi and made 467kw at the tyres...on the dyno
and ran low 10 sec passes on 28psi for 3 years until.....N1 oil pump shat itself launching at 9500rpm
rev's will kill your engine before boost will (provided its properly tuned)
https://www.sau.com.au/forums/topic/217635-rb26-rebuilt/#findComment-3843617
In terms of you wont make 440rwkw on PULP regardless due to needing decent fuel, then you need good ignition etc, its a domino effect
my interest relates to your statement of running 22-24psi then spark breaking down, obviously making 440rwkw will require fuel and solid ignition upgrades
https://www.sau.com.au/forums/topic/217635-rb26-rebuilt/#findComment-3845217
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
