hey all..
i got r34gtt just did full leather interior including the dash, and removing the air con control unit in the glovebox..
now im getting warm air through all the vent, not the driver side cause it now has guage on it..
also all the foot well (underneath the dash)..
not sure why is this happening, anyone has same experience or any idea..
thanks
https://www.sau.com.au/forums/topic/217682-hot-air-through-the-vent/
the climate control unit should have a vent somewhere to read the cabin temp, if that isnt plugged in, all they do is blow hot air until you turn it down to 18 deg.
so turn it all the way down as cold as it can get with air con on, if only then you get cold air - check the cabin temp sensor is plugged in.
yea i played around with mine today
i found that if i turned up the temp from 18 to say 26/27 i had hot air coming thru the vent, however when i turned it down to 18 the hot air stopped.. THis is with the air con off... just the fan on if you get me...
I think when u turn it down to 18, it closes off the heater hoses... so u dont get any hot air coming in.
Do you get me?
I think if u leave it at 26 or so, and even if the air con/fan is off... the vent from the heater hose is still open... So try turning it down to 18 and turn off the aircon/fan and see if u still got hot air coming out....
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
