hi guys my name is ryan
i drive a 1997 skline r33 gts-t
car is pretty basic right now, nothing special
mods list
greddy fmic, apexi safc neo, custom t3, sard fpr, powered by max 3 row radiator, FMSpower custom downpipe, FMSpower custom 3inch straight pipe ,apexi n1 coilovers, powered by max hicas eliminator bar, kaaz 2way, weld in 6pt rollcage ,5zigen fn01rc 17x9 +15 up front 17x10 +12 in the rear
https://www.sau.com.au/forums/topic/217699-hi-from-southern-california/
hi,
cool 'module' Ryan. were the 33's special imports to the US, or were they sold through Nissan [new car] dealerships?. I spend a fair amount of time in the US [latest trip, 6 months last year], but haven't seen a R32, R33 or a 34 on the road.
regards
G'day ryan,
I'm from south eastern Victoria... Nice car, it's even got the steering wheel on the correct side :)
Which kinda answers changi's questions.
Track car only? or are you getting wierd looks for sitting in the wrong seat when you stop at the lights?
  • 4 months later...
ok sorry it's been awhile since i've been on here
but here's a little update since last time
i bought all of my susp arms and links (poweredbymax RUCAS, tension rods, and 7mm tie rod spacers, Cusco front upper a-arms)
and i also bought new coilovers (CST)
and i lowered it some more
beeing doing some more comps and demos
stay tuned
should have some more upgrades within a few weeks :cool:
hi,
regards
some company called "motorex" was importing skylines - they went into receivership
i read all the police reports online regarding all the victims that lost there cars before they got hold of them
far as i know that was the only way you could get one in the usa?
it was a sponsor car
the guy who used to own it wanted to get out of it and offered it to me for an price i just couldn't refuse
you would all kill for how cheap i actually got this car for :cool:
but for the most part this is my track car
i drive it once and a while up the road a bit to get cigs and that's about it
but mos def the girls out here get hyped on it haha :rofl:
you can buy a street registered R33 GTSt for about USD$6500 these days in oz... mind you not many people seem too keen on buying them...
haha i just realised I promised to look into a windshield for you on ziptied. did you sort that out? sorry dude, I moved states since you PM'd me and everything got ballsed up.
haha what's up man!
umm ya hopefully i have coming from japan it should be here next month
but if something happens to it or it never comes
then i would be more than appreciative of your help :P
but ya skylines are suuuuuper rare here
i think there is less than 150 here in the states (registered)
from what i've heard
not too sure about that number because i haven't really checked it out myself
but i've never seen another one on the streets
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
