Nulon Oil
1C3B3RG
 Share
Nulon oil
24 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hi everyone.
I recently fell for the propaganda from Nulon. I bought Nulon 10w-40, since then been having problems. Engine revving strangely. Feels like it's not as free revving at high revs etc. I used Shell 5w-40 before and had no problems.
Has anyone tried Nulon, or had problems with it? Feedback would be appreciated. I'm trying to eliminate things to get to the bottom of the problem.
Thanks.
best to stick to the good brands ive found :nyaanyaa: but yet again your problems may not exactly be oil associated, VAC leaks, spark fuel can also cause these dramas, but as stated above if your unsure drain it replace filter and oil with quality brand and see if it helps
Good luck
probably pointless to the question your asking about nulon but i used castrol in my car once. each time i started it cold could hear tappets clicking (meaning all oil is drained out of head and not leaving a film on anything). changed it again 2 weeks later to an $80 for 4 litres motul and havent looked back since. i figure oil is like blood in your body so for the extra $50 or so when your doing a service its well and truely worth it. On the other hand some people say oil is oil but thats just my 2 cents worth!
brett
i know audi use castrol or motul if you have the R or S series , ive got shell in the Audi and motul in the skyline havent had any problem with them
every car has different clearences .. mightbe worth it changing oil n filters
P.s use oil flush t o completely get rid of old oil from the motor helps it keep it sludge free
brett
Yes, i have the same with the Nulon. Tappets clicking on start up. Highly irritating, just another bad experience i guess. Maybe i should stop being so cheap and buy good oil. I have used Nulon additives a few times and had no problems.
I was nearly tempted with nulons new synthetic, but being alot cheaper than all the other synthetics I was a bit sceptical... I stuck the good old Penrite HPR 5 and have never had an issue running it in any of my cars.
the biggest problem with nulon is not the product but the people selling it. they inform tehre customers of what grade they should be using,
i have alot of different oils in the 4 years ive had my 33 ( shell motul nulon royal purple redline VP racing oils and more) full synthetics are the way to go. you will also find that the older the engine the heavier wheight oil you need to use eg older 15w50 newer 5w30 or 10w40 winter you can use a slightly thinner oil it holds its consistancy in colder climate in summer the oil thins out as it gets hotter it will not protect the engine as much if you are using 5w30 or 10w40 in older engine.
the best thing to do is use an oil flush and put in a better oil.
i found that the best oils for me where royal purple, redline, VP racing and motul is borderline for me.
my 2 cents worth
cheers marcus
+1 for motul turobolight I used it in my NA/34 it felt much better then when the service center was putting in mobil. Its not even that expensive I think i payed like $65-$75 for like 5 liters at autobarn in browns plains. I used both 5w-40 and 10w-40 both seem to be fine id recommend motul. Never gave me a single problem and I used it for about a year and a half.
Thanks to everyone for their opinions. Good to get different ideas. I think i'll change it this weekend, also do the auto transmission fluid. I'ts due for a change, might run better too. Royal purple?
 Share
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
    • The manual says a lot about the different ratios requiring different shafts. all the Centers are the same but depending on the ratio, this determines the shafts because different ratios need the center to be offset more or less or right to left.
    • those 2 sets of shafts will not interchange and if you’re lucky you haven’t damaged anything with all your pressing and bashing you said you’ve done
    • Freshly built stroked RB25/28. Motor runs great but consumes a lot more oil then It should. This summer with the heat I was consuming roughly a quart per 1800-2000kms. Now with the cold weather coming in, I'm consuming a quart per 1000kms which is no bueno. I had originally chalked this out to break in taking a little longer then it should, but I'm now around 4000km's on this engine. I think it's fair to say something isn't quite right. Here's the kicker, can't find what's causing it. I've also spoken to my engine builder and Precision Turbo and can't figure it out. Here's my train of thought on possible causes and what I've done.  Precision Turbo - I originally started thinking my oil pressure might be a tad too high for my 6466 Gen2. I took the center cartridge out, and while yes there's signs of oil on the turbine heatshield, it's very moderate. There's also very minor in/out play that concerns me. I sent pictures and videos to precision and they said the residue and in/out play is minimal and they doubt this is the issue. For piece of mind, I went ahead and installed a Turbosmart OPR V2 to bring oil pressure down. Made no difference. Precision is willing to take it in on RMA for an inspection and I'll probably take them up on that offer for peace of mind. BTW. Is it just me or does the turbines inducer's look clipped and not even between each other? I just noticed this now while posting and looking at the picture zoomed in. Might just be the picture...  Rings - Hot compression test and leak down test look good. Compression is 160 +-2psi across the board. I leak down at 16% on cyl 1,2,3,5,6 and 18% on cyl4. Keep in mind I have a snap on leak down tester and they read high (I.E, 15% on my wifes 2018 Sentra with 70000kms). Sparkplugs show minimal oil (Only #4 seems to have a tad). At a quart per 1000km's though, I would be expecting them to be wet. Here's the kicker, I run WMI. I'm thinking what if my compression rings are great, but I have an oil control ring issue on cyl4 and my WMI is steam cleaning the pistons and sparkplugs? I can still see the "Spool" logo on top of my CP pistons. The only time I see smoke out of the exhaust is in the high rpm/load range. So far, this is my main culprit. I'll probably turn off my WMI and go out with the car at spring pressure tomorrow and repull the plugs. Other thing that's strange though is that I have never seen any oil in my catch can. Thing is still dry after 4000kms. Cyl1 - Left, Cyl6 - Right. Valve seals - They're new and I would expect oil consumption on idle, first cold start or during decel. None of which is happening.  Crankcase pressure - I have 2x 10an valve cover lines to a vented catch can. Head drain and opened up internal oil drain paths. I also don't run E85. I've never seen any oil in my catch can. Doubtful this is causing any issues.  Rear main seal - I have no visible leaks, but figured maybe it was my rear main seal. After now having added 2-3 quarts, I would expect oil to leak out the bottom drain channel and/or my clutch to be slipping.  Let me know your thoughts. With winter coming and taking the car off the road until spring, I'm fine with pulling the motor apart but I would hate to take it all apart and the turbo was the issue in the end.
    • Actually, the best option is probably to get some of the stronger aftermarket driveshafts that have both the 5x1 and 3x2 pattern on them, so OP can do whatever the hell OP likes with the diff in the future and not have all this angst. I posted a link to them sometime in the last 2 weeks, I'm sure.
