Why whats she making now???
I dont know how much more i will get from my next tune. Should be a bit. :)
About 305awkws at 18psi im hoping that with 22-24psi and the cam gears played with 350-360awkws can be had but who knows this car never dose what its told. My exhaust is the main problem but i like to keep it quite now days.
  • Replies 344
Posted Images
"What are the new tyres you are putting on?"
I have gone for some more Toyo T1R's in 265/35ZR18. I run these on my GTR and they provide good grip especially in the wet with their open tread pattern. The only draw back is that they are noisy which simply means turning up the sterio.
Victory ....... how wide are your rims ? mine are 9 inch and I run 255's but I would like to run 265's. Do think the 9's would handle the 265's alright ?
Tim.
Sorry to butt in, I have 18 x 9's on my R32 with 265/35/18 & have no probs with fitment :P .
I'm sure you wouldnt either champ ;) .
I know that this has probably been asked before but why are we not showing the times from the back track in the afternoon?
I dont think that the morning times should be the bench mark because the track temp was cold and there was little grip especially for those people using semi slick tyres. There was also a lot of loose stones and dirt on the surface in the morning.
The grip level in the afternoon was substantially better because the track temp was higher and there was less crap on the road surface - therefore giving the drivers a better chance to utilise their driving skills knowing that the car was less likely to lose traction.
Perhaps an average from the morning and afternoon runs should be worked out and used as a comparison? :)
I run 265/35ZR18 on 18 x 9 rims and they fit perfectly.
The only problem is that the OD is 644 mm and is a fraction small when the correct OD is 650. This means your actual speed is about 5km less that what your speedo shows. This is what most car companies do so that you are just under the speed limit.
I was running 245/40ZR18 on 18 x8 with an OD of 651 which gave me the exact speed on the speedo in both the GTR and GTS-T. I was going to go for 275/35ZR18 to get back to an OD of 649 but Toyo only had 2 in the country and were hoping to get in another 6 in July. Even though they would have been the exact tyre for the car if they are that rare then if you stuffed one it would be a real pain to try and replace it.
Not a bad figger to go for.
What cams are in it?
Also i use 255/40zr/17
Not enough grip for my monstor on its run in tune :) Cant wait to wind up the boost. :P
Edited by BNR32t
evil weevil, Chris' camera is a GoPro, same as mine.
www.goprocamera.com then go to the Motorsports Hero.
I got mine from http://www.soloperformance.com/ in the USA as well as a CruiseCam headrest mount for about 310AUD all told.
User NISMO also has one which he got locally.
Here is some video I took from Wakefield. I had the sound on the wrong setting for in-car though. And the footage is much smoother when you use the included suction cup. And yes, I damn near **** myself at the end of the video hahaha
Me making an area of myself
ooh pick me pick me!! :P yeah i'm interested ;)
I'm have the costs for the actual products. I just need to find out costing of freight from them to me and then postage from me to you which will just be those post packs either exp or stnd.
Hopefully It will be cheap cheap.
As soon as I find out I will post up and see if we can get it happening.
can that camera be used as a normal video camera, like hand held? if so i might have to get one as well!
I'm not sure but I will look into it.
There is a guy doing them in TAS section but I'm getting them a lot cheaper.
lol made an "area" of myself.. damn, nice price VZSS!
They CAN be used as a hand held camera, however they are so small that you might find you aren't really pointing in the direct you think they are. I wouldn't rely on them for that kind of use. CeJay I can show you mine if you like. I'll bring it the next Friday I'm out.
One really important thing is that this camera will NOT pickup any footage whatsoever (ie nada, zip, zero) at night time. I went for a drive at night and I could only JUST make out the halo from streetlights, and nothing else. And it BARELY picks up any footage indoors during the day, or at night with the room's lights on (ie the footage is so dark you can't make anything out). Even when I faced this thing towards a desk lamp, it is VERY poor quality. It really needs UV/daylight to work properly.. go figure. I was hoping to use it for night time cruise footage, but it is useless for that. I was really disappointed about this part, but I mostly bought it for analysing laps and stuff during the day, so it's alright for me.
The other thing is, Wakefield Park (and probably many other tracks in AU) will not let you use this camera with the including suction cup mount. If you want to use it on the track, you'll need to get a proper bolt on fixture, like the "Cruise Cam" i mentioned in an earlier post.
Other than that, it's great - you can see what footage is captures in it's ideal conditions. Oh, and the other thing: it chews batteries like a mofo. Lithium or BUST!
Edited by sl33py
    • Welcome. This is not really true. We have a whole forum here just for the NA shitboxen. And they are not very different from the turbo shitboxen. Just weaker brakes and gearboxes, and no LSD, for the most part.
    • I'm pretty sure it has an 040 in it @Duncan Also reading up, that turbo should top out at 250 as you first thought. It will be interesting to see how early it chokes due to the changes in the head too
    • Yeah confirmed they are Nismo 555s, found the boxes in the spares with the factory injectors in. Yeah the AAC has been relocated to allow reuse of the factory brake booster line, and yes confirmed it has a 1 way valve in it. Unfortunately the one on the car is cracked, I'll need to replace it. Pretty sure I've got all the AAC plumbing correct in my previous post, but I am going to source some new fittings with 90o angles to help with the hose routing and also one really specific moulded shape for the AAC intake to cold start hose (will raid the back of our local repco when I get a chance and work out some combo that works) One of the big things I learned in the GTR is you need to be able to get your hands all around the bay when something goes wrong. I've done a bunch of re-routing now and it should be much more practical now. Also got the BOV mount re TIG-ed by the local engineering shop so that should be good to go now. Never got to the fuel pump because of some life stuff today, but will pull it to confirm it is suitable for 300rwkw when I get a chance
    • Hello everyone, I am from Malta and have recently bought myself a fully stock 1992 Nissan Skyline GTS. It has the RB20DE engine and thus is NA. Unfortunately, not a lot of information can be found online related to the GTS, unlike the information for GTS-T and GTR variants. Apart of the Skyline, I also got a 1984 Porsche 924 2.0l NA and a 2002 Renault Clio 1.5DCi for everyday use. Excited to be apart of the community and perhaps get better information on cars such as the GTS.
    • The fuel pump bracket just slides straight up.  Below is a pic I stole off a site. But basically put hand in for fuel pump, wiggle it all about a bit while pulling up.
