Clutch pedal gone all of a sudden whilst driving ...
Hey,
I was driving along yesterday and went to change from 2nd to 3rd when the clutch pedal just seemed to fall to the floor. Now when I push the clutch pedal down it doesn't disengage the clutch properly. I have to push the pedal as hard as i can to get the car into gear and to get it home i had to blip the rev in between shift so that it wouldn't crunch gears. It's going to Bezerkly tomorrow to get checked out just wondering if anyone could give me an idea of whats going on cause its doing my head in...
Thanks :nyaanyaa:
Hey,
Thanks :nyaanyaa:
most likely your clutch master cyl is gone
change the slave cyl as well if you're doing the master cylinder
check your clutch fluid level, if it's too low then top it up, pump the pedal up and drive it carefully to the mechanics to get it fixed
the genuine master and slave cylinders aren't that expensive from nissan, so just save yourself the hassle and get new ones instead of messing around trying to rebuild/reseal the master cyl.. if the master cyl bore is scored then u've wasted your time rebuilding it
I Wish I had an easy fix like that :(
Just Pulled my slave off to change as I thought it had gone only to find that the locating/pivot bolt for the clutch fork has snapped...Yay Gearbox has to come out now :)
speaking of spot welds on the pedal brackets..
this reminded me that few days ago when my friend's r33 got broken into when parked on the streets in redfern/waterloo area
nothing was stolen, all they did was they pulled the brackets out of the accelerator pedal
and punctured one rear tyre..
when i saw it i was surprised how it didnt seem too hard to pull the bracket out... done with just a bit of leverage, force wasnt even enough to bend the bracket
with clutch pedal being heavier than accelerator, especially if you have heavy duty clutch, i guess it'll become a weak point..
why would they pull the accelerator pedal box out?
that is quite random! :thumbsup:
ya it is
and popped one of the tyres too
the parking spots close to city, on the streets, in front of some houses..
they probably didnt like him parking there so decided to do something to his car so he won't park there
whoever did it knew skylines quite well by the way it was broken into...
I Wish I had an easy fix like that :P
Just Pulled my slave off to change as I thought it had gone only to find that the locating/pivot bolt for the clutch fork has snapped...Yay Gearbox has to come out now :D
Same thing happened to my friend last weekend at DECA in Shepparton, had to drive it back to melbourne with no clutch starting it in gear. Do you know if there's anything that gets left inside the box that could be left dangling and doing damage to the inside of the gearbox?? Sorry don't mean to hijack thread..
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
