well
sounds stupid i know, BUT its true (in my case)
Normally i average 200-250Km a tank
well, after i put this new to4e turbo on....i got 280KM to a half of a tank...
ao thats over 500KM to a tank if i calculate it correctly
ill do a test since i have to fill it up anwyays and i will have a week before i get a tune.
more on that later
yeah, im curious to see gas mileage between rough tune and after Rom tune with more fuel delivery parts installed.
im hoping 450+ KM a tank...if i can get 300 id be happy
this 250km a tank is killing me
its huge
i had to grind part of the compressor housing to fit it on the stock manifold (stainless had a huge ass crack so i threw it away)
its a t04E size compressor
50 trim
i get 10psi at 4k rpm
im imagining 1 bar at 4300-4500rpm
when i get home i will throw up a picture of it next to a stock turbo for comparrison
well sounds stupid i know, BUT its true (in my case)
more on that later
What did you do, run it on 2 cylinders only? :)
Whats that knocking noise I hear? :(
lol
nah
AFs are in the low 13s accross the board
i had liek 2 horus to tune it on the highway.
and nah, i drive my car like a bat out of hell.
thats why i have to maintain it all the damn time.
im never out of boost normally
Should have gone Autech Grant. 650hp, 400kms a tank.
well that makes no sense to me .. hopefully someone will tell is what the go is
same here, thats why i was like WTF
so far 67 kms of hard city driving and it is still at hte full mark.
Yep, big turbo would be to blaim, when you're cruising along on the highway or whatever it is making less boost and the ECU runs is leaner.
It was the same for me with my old R31 that a HT-18 on it. Most the time was off boost, so fuel efficiency was awesome. As soon as you get up, you can just about watch the fuel needle dropping! A friend of mine with an R32 also has similar affects.
    • Welcome. This is not really true. We have a whole forum here just for the NA shitboxen. And they are not very different from the turbo shitboxen. Just weaker brakes and gearboxes, and no LSD, for the most part.
    • I'm pretty sure it has an 040 in it @Duncan Also reading up, that turbo should top out at 250 as you first thought. It will be interesting to see how early it chokes due to the changes in the head too
    • Yeah confirmed they are Nismo 555s, found the boxes in the spares with the factory injectors in. Yeah the AAC has been relocated to allow reuse of the factory brake booster line, and yes confirmed it has a 1 way valve in it. Unfortunately the one on the car is cracked, I'll need to replace it. Pretty sure I've got all the AAC plumbing correct in my previous post, but I am going to source some new fittings with 90o angles to help with the hose routing and also one really specific moulded shape for the AAC intake to cold start hose (will raid the back of our local repco when I get a chance and work out some combo that works) One of the big things I learned in the GTR is you need to be able to get your hands all around the bay when something goes wrong. I've done a bunch of re-routing now and it should be much more practical now. Also got the BOV mount re TIG-ed by the local engineering shop so that should be good to go now. Never got to the fuel pump because of some life stuff today, but will pull it to confirm it is suitable for 300rwkw when I get a chance
    • Hello everyone, I am from Malta and have recently bought myself a fully stock 1992 Nissan Skyline GTS. It has the RB20DE engine and thus is NA. Unfortunately, not a lot of information can be found online related to the GTS, unlike the information for GTS-T and GTR variants. Apart of the Skyline, I also got a 1984 Porsche 924 2.0l NA and a 2002 Renault Clio 1.5DCi for everyday use. Excited to be apart of the community and perhaps get better information on cars such as the GTS.
    • The fuel pump bracket just slides straight up.  Below is a pic I stole off a site. But basically put hand in for fuel pump, wiggle it all about a bit while pulling up.
