well
sounds stupid i know, BUT its true (in my case)
Normally i average 200-250Km a tank
well, after i put this new to4e turbo on....i got 280KM to a half of a tank...
ao thats over 500KM to a tank if i calculate it correctly
ill do a test since i have to fill it up anwyays and i will have a week before i get a tune.
more on that later
yeah, im curious to see gas mileage between rough tune and after Rom tune with more fuel delivery parts installed.
im hoping 450+ KM a tank...if i can get 300 id be happy
this 250km a tank is killing me
its huge
i had to grind part of the compressor housing to fit it on the stock manifold (stainless had a huge ass crack so i threw it away)
its a t04E size compressor
50 trim
i get 10psi at 4k rpm
im imagining 1 bar at 4300-4500rpm
when i get home i will throw up a picture of it next to a stock turbo for comparrison
well sounds stupid i know, BUT its true (in my case)
more on that later
What did you do, run it on 2 cylinders only? :)
Whats that knocking noise I hear? :(
lol
nah
AFs are in the low 13s accross the board
i had liek 2 horus to tune it on the highway.
and nah, i drive my car like a bat out of hell.
thats why i have to maintain it all the damn time.
im never out of boost normally
Should have gone Autech Grant. 650hp, 400kms a tank.
well that makes no sense to me .. hopefully someone will tell is what the go is
same here, thats why i was like WTF
so far 67 kms of hard city driving and it is still at hte full mark.
Yep, big turbo would be to blaim, when you're cruising along on the highway or whatever it is making less boost and the ECU runs is leaner.
It was the same for me with my old R31 that a HT-18 on it. Most the time was off boost, so fuel efficiency was awesome. As soon as you get up, you can just about watch the fuel needle dropping! A friend of mine with an R32 also has similar affects.
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
