how does next sat work? i can come up in the morning and leave it with u as long as u need it!
and wat do u drink haha!
u dont know how much i apreciate it!!
thanks a million!
I drink Pale Ale :)
So you want the job done not this Sat coming but next Saturday?
I can do the job in about 2-3 hours depending on hassles (GF being one LOL) and if it is a direct bolt on, as I'd rather not have your car in my neighbourhood too long. But I do have a clublock and lockup carport anyway. Might even see if Grim would like to help out (he has more tools and doesn't drink LOL)
However, I'd like see the car and the turbo beforehand so I can eyeball the job and make sure it'll be straight forward-ish! LOL
Oh, and there is the usual disclaimer I say to all my mates: I wouldn't drive/joyride your car, but it is still stored at your own risk ... blah blah, you know how it goes :( (but I will endeavour to take measures to protect your ride - such as the club lock and staffie) :blink:
You going to Bunny's cruise/meet this Friday night? We can discuss then.
  • Replies 77
Has the turbo been off before?? If its stock, and has never been off you may want to check all your exhaust manifold studs into the block are still in place before you start from underneath the car, if you pull the turbo off and and you can see that one of the bolt heads is missing, ( i think there are 14), your budget might blow out a bit to fix it properly. Alot of people leave them broken and don't attempt to pull off the manifold but the proper way to do the job is to replace the broken stud, which usually turns out into more than 1 stud, and a manifold gasket because it will def be leaking and will eventually need to be done, so you dont want to have to pull the turbo back out at a later date. And make sure you don't drill through the head into the oil galleries, seen it done before by a 'professional' on site head stud removing specialist. Not saying its def. going to happen but be prepared with all the right tools otherwise your time frame may blow out (its may be difficult to source all the required parts on a weekend). I had no idea and was going to attempt it myself a couple of weekends ago, glad i just paid and got it professionally done. I had 4 broken studs up near no. 6 cyclinder with abs module in the way and bugger all room to get a right angle air drill with cobalt drill bits and a sharp centrepunch perfectly in the middle. Glad i didn't attempt it myself. Just a warning.
fund raising for more sausages?
well selling sausages for more money for the club to do whatever it does with its money.
or, have a sausage sizzle, so we can fundraise for a big free sausage sizzle :(
lol, SAU event..........supply a few cartons & snags rad33, invite a couple dozen members and everyone can get their hands dirty :(
hmm getting me thinking!! i have coilovers and gtr injectors to fit lol...
hahaha but the thing its n being done at my house!
Are we still going ahead with the turbo swap tomorrow? Will you be dropping the car off in the morning?
PM me back, or see me tonight if you're on the cruise again, for my address.
Ruby
cheers reuben!!!
much apreciated mate!!
No worries! I read in a nother thread you have a coolant leak?
I'll ask you not to drive the car until you can confirm where the leak is coming from, or (most importantly) where the coolant is going too.
Call me mid morning if you can't confirm where the leak is coming from.
I'd rather not see your car break down.
Ruby
    • My understanding is that UV tends to accelerate the aging process. If the car has been garaged, then you could probably get away with extending beyond 10 years. FWIW, in 2015, I had tyres on my 180B SSS that had a 3-digit code (2 for week, 1 for decade), ending in 0, so could have been more than 30 years old, but still worked fine. I did replaced them very quickly, though, once I discovered what the code meant!
    • But we haven't even gotten to the point of talking about stateless controllers or any of the good stuff yet!
    • You guys need to take this discussion to another thread if you want to continue it, most of the last 2 pages has nothing to do with OP's questions and situation
    • And this, is just ONE major issue for closed loop control, particularly using PID. One such issue that is created right here, is integrator wind up. But you know GTSBoy, "it's just a simple PID controller"...
    • Nah. For something like boost control I wouldn't start my design with PID. I'd go with something that originates in the fuzzy logic world and use an emergency function or similar concept. PID can and does work, but at its fundamental level it is not suited to quick action. I'd be reasonably sure that the Profecs et al all transitioned to a fuzzy algorithm back in the 90s. Keep in mind also that where and when I have previously talked about using a Profec, I'm usually talking about only doing an open loop system anyway. All this talk of PID and other algorithms only comes into play when you're talking closed loop boost control, and in the context of what the OP needs and wants, we're probably actually in the realm of open loop anyway. Closed loop boost control has always bothered me, because if you sense the process value (ie the boost measurement that you want to control) in the plenum (after the throttle), then boost control to achieve a target is only desirable at WOT. When you are not WOT, you do not want the the boost to be as high as it can be (ie 100% of target). That's why you do not have the throttle at WO. You're attempting to not go as fast as you can. If the process variable is measured upstream of the throttle (ie in an RB26 plenum, or the cold side pipework in others) then yeah, sure, run the boost controller closed loop to hit a target boost there, and then the throttle does what it is supposed to do. Just for utter clarity.... an old Profec B Spec II (or whatever it is called, and I've got one, and I never look at it, so I can't remember!) and similar might have a MAP sensor, and it might show you the actual boost in the plenum (when the MAP sensor is connected to the plenum) but it does not use that value to decide what it is doing to control the boost, except to control the gating effect (where it stops holding the gate closed on the boost ramp). It's not closed loop at all. Once the gate is released, it's just the solenoid flailing away at whatever duty cycle was configured when it was set up. I'm sure that there are many people who do not understand the above points and wonder wtf is going on.
