G'day all at the SAU forums.
seems this is my first post here, il introduce myself
just bought a 1994 R33 GTS25.
met grey, dead stock (minus Blitz Nur Spec R zorst), Turbo front bar.
needs a few bits of work done to it, which il describe here
- CAI: Have already had a poke around the forums at this, shouldnt be too hard, looking to build a custom airbox for it aswell
- 5stud converstion (maybe?): How much benefit/what is requiered to perform this? im thinking if i get the GTS-T brakes then this will probly be neccesary, but correct me if im wrong
- Rims (dependant on the above): dished 5spoke of snowflake?
- GTS-T brakes: how hard would these be to track down, my brake atm are shocking. whether its just the fact they need new pads or they are too small, im still not sure. someone said that they were silvia-spec brakes, which makes me worried cos the 33 is a tad heavier...
- ABS (possible to retrofit?): would help alot with the lock ups that are way to easy to do atm. would compliment the T brakes nicely
- Full stereo system (to come much later): will discuss later
theres also other little bits and pieces like clear indicators and floormats etc, but all those things are possible wihtout much consultation, the above items i need some help on deciding on.
so yeah, thats my car, any help is appreciated :(
https://www.sau.com.au/forums/topic/217877-new-33/
Welcome!! Your car reminds me of my old gun grey 33 gts, before I kitted it, added stereo, exhaust/extractors/ CAI and Bride copy seats went into it (which I miss) Stock s13 seat is a bitch lol =)
Just upgrade to the entire GTS-T breaking/Hub/stud assembly.
You'll have bigger breaks, wider choice of wheels. Check wreckers, fs threads etc.. Pretty cheap to do if you can do the labour yourself!
Just aim for lightweight rims with a flush offset! (No dinner plate chromies)
Not sure about ABS...
Edited by ignuz
https://www.sau.com.au/forums/topic/217877-new-33/#findComment-3844782
what he said!
get exhaust for it too, try the ones with big muffler rather than cannons, or it'll get too loud and drowny on na.
or just get r33 gtst exhausts for a cheap upgrade
abs is good but you'll need a lot of effort finding and installing it, maybe costly too
you'll at least need sensors on all 4 wheels, electric wiring and relay, abs assy, lines, and new brake master cyl...
probably not worth it in the end
just upgrade to gtst brakes and some nice progressive pads, and good tyres
https://www.sau.com.au/forums/topic/217877-new-33/#findComment-3845303
what he said!
iv already got a Blitz cat-back exhaust, 2.5" (i think) came like that. and it sounds tuff.
ABS sounds like way too much effort...GTS-T brakes along with the 5stud conversion seems to be the way to go. would i need spacers if i go with the 5stud, and go for something along the lines of 8/8.5" width tyres?
Edited by G0DZLR
https://www.sau.com.au/forums/topic/217877-new-33/#findComment-3845738
something that seems to be an issue, my aircon belt makes an intolerable scream when cold...i know this is common on older cars, but you know its kinda embarrassing when you start your car up in the main street and get that noise...
other than taking it to a service center, is there anyway of rectifying it otherwise?
https://www.sau.com.au/forums/topic/217877-new-33/#findComment-3852785
tighten the belt and or belt grease with u can find at an automotive shop of somekind probly bursons
anyway welcome nice car if you cbf building a cai there a guy that sells them on ebay for gts's and the bolt straight up there abour 90$ including shipping
mm you need a set of wheels bad lol ahh well
let me kno how you go with the gtst brake conversion im pretty interested myself
https://www.sau.com.au/forums/topic/217877-new-33/#findComment-3853063
Nice car dude :D Mate get the turbo hub\brake conversion onto it and u'll pull up great without abs... I have never not been able to pull my non abs gtst up in a hurry when needed..
Hows the standard head unit treating you? lol that would have to be one of the first things u'll change yeah? :laugh:
https://www.sau.com.au/forums/topic/217877-new-33/#findComment-3876244
yes, head unit goes, in a few months. first thing is gonna be wheels actually :P
http://www.speedywheels.com.au/images/zoom/wheels/lite-7-gunmetal.jpg
or
http://www.speedywheels.com.au/images/zoom/wheels/lite-5.jpg
note: these are if i decide to stay 4stud, which by the looks is going to be cheaper/less hassle...
https://www.sau.com.au/forums/topic/217877-new-33/#findComment-3876254
Man I love your front bar any idea where the best place to get one like that?
post an add in the WTB section, im sure youl luck across one some day
can someone tell me whether a SII rear wing will fit my SI? or whether they made the SII wing in the SI and im just having a mental blank now :S im sort of over my low-rise aero wing. its either that or a lip.
Edited by G0DZLR
https://www.sau.com.au/forums/topic/217877-new-33/#findComment-3876773
  • 3 weeks later...
just performed my first proper mod, dual highbeams :thumbsup:
very pleased wiht this neat little mod, it really makes a HUGE difference on the open road. and its as simple as 2 solder joints xD
enjoy pics
(imo looks much better too)
https://www.sau.com.au/forums/topic/217877-new-33/#findComment-3925008
    • Way more than 1cm. Appreciate the advice maybe I try changing the bushing first
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
