So as you may notice, the N/A forum now has 1000 posts threads!!
Some of you may be thinking who cares?
Well It's a great accomplishment, believe it or not, the forum only had around 300 or so topics if not less back when I joined SAU (2004). And most of those topics weren't even initially created in this forum.. You see the N/A section wasn't here from the beginning..
The Naturally Aspirated section was left out in the rain in SAU's early years, with little enthusiam for the screaming 6 cylinder!
This was changed by an early 'pioneer' of the N/A forums.. 'Greg'
Before the N/A forum, there was a thread devoted to the N/A skyline! http://www.skylinesaustralia.com/forums/Na...rea-t2344.html#
Greg took it upon himself to gather the enthusiasm of all N/A owners, in doing this he helped turn the N/A community into what we see today! Along with PVA_glue the first N/A moderator they pushed to help out all those with non-turbo skylines..
A year or so later Eug arrived on the scene. Learning from the forums along the way and learning new ways to improve the N/A skylines, helping others and just generally answering every post that seemed to come up, he quickly earned himself moderator title :)
Once the non-turbo laws hit some of the states, posts started booming, more and more people started waking up and realising N/A skylines can handle and perform far beyond most people's expectations!
And so the forum as you see it today celebrates 1000 posts threads! A great accomplishment for all those who put time into writing up tutorials, FAQ's, Answering questions and in general just helping each other out and promoting ownership of N/A skylines not just across Australia but internationally too!
Well done guys!
P.S No more threads on, how do make a pshhhhhht sound anymore kk? :(
https://www.sau.com.au/forums/topic/217896-1000-one-thousand-10x100/
YAY..
Its good to see that NA's are gaining a certain mount of respect in the shadow of their turbo cousins..
I have a feeling we are still yet to see big things out of the ye ol' DE
But just one last question..
I just got an NA 33 and I want ti to go psssshhhhhht.. how do I do this?
congrats N/A performance id like to thank the main guys on helping everyone with there questions and lets continue doing so.
now down to business what exhaust should i get and how much power does my car come with and can i put a turbo on it? lol :whistling:
excellent work guys... love your support!
ROFL!!!!!!!!!!! this cracked me up
p.s. - first post fixed for accuracy :blink:
Hahha posts.. threads.. dammit made that mistake twice now.. I didn't get alot after trolling through the old SAU archives.
And that face is win!
Edited by ignuz
Should edit the thread title too :blink:
AHhh how did I make that mistake THREE times lol?!
Edit: doesn't seem to be an option to edit the title.. Can only do my most recent post it seems.
Edited by ignuz
Really? Haha didnt know that.
And gotta fix this part too:
"And so the forum as you see it today celebrates 1000 posts!"
:blink:
nice pick! four times now...
So my name is cris.. Im 16.. just got an NA R33..
I want exhaust.. what should I get? What is best?
And on the topi.. what pod filder is best?.. Or Pod V Panel
gtfo :(
  • 4 weeks later...
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
