Hello
I know these typical engine rebuilds threads have been covered numerous of times however, I personally just want to obtain others' perspective. As per topic, my engine is experiencing some 'bearing' issue(s) at the moment and decided to rebuild bottom-end however, weighing factors between a forged and standard I'm having dramas finalizing. My aim for the vehicle in terms of power output would be a solid 250kw or so, is a daily driven for work, uni and I intend to keep it for awhile.
If budget was not a matter of concern, which type of rebuild would you prefer and why?
Thanks in advance :whistling:
if budget is not a matter of concern?
forged rebuild of course. peace of mind knowing you have stronger than factory internals
even if budget was a matter of concern. when you factor in the engine out and labour, it would be worth while spending the extra little bit and getting the forged rebuild over the standard.
just my opinion.
can you build a light tuff engine? Dont go silly on it. Just throw some nice pistons in, and have everything balanced...
what I would do for the power level...
just my opinion.
i agree but, do you believe it would be such a waste/overkill having top notch engine components on a daily driven vehicle?
I agree with ^
why not an Rb30det?? Thats what i have planned when/if my engine goes.
RB30? hehe I actually haven't searched into that option yet however, I did considered a stroker 2.8l kit :laugh: Some were emphasizing the fact that mine isn't a dedicated race car (hence, waste of investment unless I'm trying to squeeze every kw :banana: ), while others were encouraging to get it.
Yeah I want to make a smart investment ("not going silly") and do intend to have a turbo upgrade (HKS GT-RS) down the track preferably after the rebuild. At the moment in relations to the forged I do have two options as I can see: 1) regular forged or 2) stroker kit
I guess not having a budget does create this drama but, any opinion you fellas advocate will be much appreciated!
also i think there's a rb25det for sale in the classified section for around the $750 , complete motor. it's your 'other end of the spectrum' cheapo fix
when my bearings went on my sr20, i hunted around for a pre-built forged bottom end and got one shipped from interstate. cost me $2800, supported 350rwkw+.
make some calls to some tuners you know or some local performance shops and see if they have any built rb25 / rb30 bottom ends you could buy :laugh:
Honestly my oponion would be to buy a cheap rb25det that is in good condition and chuck it in and continue your voyage to 250rwkw. Keep in mind the stock bottom end still has another 50rwkw in headroom and is still considered safe hp for the engine.
Dont waste your money rebuilding the engine. Buy another one for $1500 and sell your old one for $750 and your laughing.
RB25 will do your 250rwkw standing on its head.
New bearings,
New pistons wisco for cheap cp tomei hks for top end
all new seals
rod bolts head bolts big end ARP items
cranck collar
N1 pump
maybe cams or just cam gears
s15 injectors
bigger turbo gtr-s is good or 2535
power fc with boost kit or avcr
tomei or cometic head gasket
Basic build about 3-5k if you pull it out and put it back in your self
Also think about shot peneing the rods
and get it all balanced
make some calls to some tuners you know or some local performance shops and see if they have any built rb25 / rb30 bottom ends you could buy :P
Hrmm, will give this option ago as well and see what I can dig up. While I'm at it might search for RB26 LOL!!
I'll probably pass on this, I know a fair amount of money is involved labour wise but, in the end I do want to keep the car for awhile (few more years) so getting everything brand new is the direction I want to follow.
New bearings,
all new seals
cranck collar
N1 pump
s15 injectors
N1 pump, is it necessary to include them? I presume its water and oil? :P
When you are after something in the 300+range. The oil pump atleast.
Though people will tell you plenty of cars get into the 300's in standard motor trim with a big turbo bolted to the side.
IMO if you are doing a full rebuild why skimp on good parts.Id want to make sure all the bases were covered.
As you said, budgets not a problem and if you intend to keep the car and pay for the labour involved in taking apart and in and out, then you might as well get it rebuilt with uprated internals. And since the oil pump is basically a motor out job, you might as well spend the couple hundred bucks on doing it, which gives you the option of having 300+kw later on.
Just a word of advice, what an engine build is budgeted to be at the beginning always ends up a couple grand more from my experience, so just budget for that.
Edited by Yawn
Couldnt agree more. Alot of people budget for parts and labor but its always the little things that blow the budget out a tad.New lines and piping,replacing tired parts ect ect.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
