Hello
I know these typical engine rebuilds threads have been covered numerous of times however, I personally just want to obtain others' perspective. As per topic, my engine is experiencing some 'bearing' issue(s) at the moment and decided to rebuild bottom-end however, weighing factors between a forged and standard I'm having dramas finalizing. My aim for the vehicle in terms of power output would be a solid 250kw or so, is a daily driven for work, uni and I intend to keep it for awhile.
If budget was not a matter of concern, which type of rebuild would you prefer and why?
Thanks in advance :whistling:
if budget is not a matter of concern?
forged rebuild of course. peace of mind knowing you have stronger than factory internals
even if budget was a matter of concern. when you factor in the engine out and labour, it would be worth while spending the extra little bit and getting the forged rebuild over the standard.
just my opinion.
can you build a light tuff engine? Dont go silly on it. Just throw some nice pistons in, and have everything balanced...
what I would do for the power level...
just my opinion.
i agree but, do you believe it would be such a waste/overkill having top notch engine components on a daily driven vehicle?
I agree with ^
why not an Rb30det?? Thats what i have planned when/if my engine goes.
RB30? hehe I actually haven't searched into that option yet however, I did considered a stroker 2.8l kit :laugh: Some were emphasizing the fact that mine isn't a dedicated race car (hence, waste of investment unless I'm trying to squeeze every kw :banana: ), while others were encouraging to get it.
Yeah I want to make a smart investment ("not going silly") and do intend to have a turbo upgrade (HKS GT-RS) down the track preferably after the rebuild. At the moment in relations to the forged I do have two options as I can see: 1) regular forged or 2) stroker kit
I guess not having a budget does create this drama but, any opinion you fellas advocate will be much appreciated!
also i think there's a rb25det for sale in the classified section for around the $750 , complete motor. it's your 'other end of the spectrum' cheapo fix
when my bearings went on my sr20, i hunted around for a pre-built forged bottom end and got one shipped from interstate. cost me $2800, supported 350rwkw+.
make some calls to some tuners you know or some local performance shops and see if they have any built rb25 / rb30 bottom ends you could buy :laugh:
Honestly my oponion would be to buy a cheap rb25det that is in good condition and chuck it in and continue your voyage to 250rwkw. Keep in mind the stock bottom end still has another 50rwkw in headroom and is still considered safe hp for the engine.
Dont waste your money rebuilding the engine. Buy another one for $1500 and sell your old one for $750 and your laughing.
RB25 will do your 250rwkw standing on its head.
New bearings,
New pistons wisco for cheap cp tomei hks for top end
all new seals
rod bolts head bolts big end ARP items
cranck collar
N1 pump
maybe cams or just cam gears
s15 injectors
bigger turbo gtr-s is good or 2535
power fc with boost kit or avcr
tomei or cometic head gasket
Basic build about 3-5k if you pull it out and put it back in your self
Also think about shot peneing the rods
and get it all balanced
make some calls to some tuners you know or some local performance shops and see if they have any built rb25 / rb30 bottom ends you could buy :P
Hrmm, will give this option ago as well and see what I can dig up. While I'm at it might search for RB26 LOL!!
I'll probably pass on this, I know a fair amount of money is involved labour wise but, in the end I do want to keep the car for awhile (few more years) so getting everything brand new is the direction I want to follow.
New bearings,
all new seals
cranck collar
N1 pump
s15 injectors
N1 pump, is it necessary to include them? I presume its water and oil? :P
When you are after something in the 300+range. The oil pump atleast.
Though people will tell you plenty of cars get into the 300's in standard motor trim with a big turbo bolted to the side.
IMO if you are doing a full rebuild why skimp on good parts.Id want to make sure all the bases were covered.
As you said, budgets not a problem and if you intend to keep the car and pay for the labour involved in taking apart and in and out, then you might as well get it rebuilt with uprated internals. And since the oil pump is basically a motor out job, you might as well spend the couple hundred bucks on doing it, which gives you the option of having 300+kw later on.
Just a word of advice, what an engine build is budgeted to be at the beginning always ends up a couple grand more from my experience, so just budget for that.
Edited by Yawn
Couldnt agree more. Alot of people budget for parts and labor but its always the little things that blow the budget out a tad.New lines and piping,replacing tired parts ect ect.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 馃槈. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 馃槏.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 馃檹 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 馃槈. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 馃槏 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
