Hey,
any one out ther etried the Falken FK451's ?
in particular on standard R33 GTSt rims?
they seem like a really good tyre, but I was told that the Falken tyres are alot better in the larger/wider tyre sizes... can any one confirm/deny this?
I was looking at just replacing th estock the stock tyres on the stock rims, but not too sure... any other suggestions?
Also, just to confirm... R33 GTSt stockies are 16*6's y/n?
I've been told 16*6's and 16*6.5's... and I'm too lazy to take the wheel off :D
Thanks
https://www.sau.com.au/forums/topic/21792-falken-fk451s/
I saw these 2 threads... and other stuff from other forums and on the net... just a bit worried about putting them on the stock rims though.
Ah well, I'll give them a whirl and see how they go, got about 1 mm on the back and 2mm of tread on the front... have to bite the bullet and find something soon!
Thanks,
https://www.sau.com.au/forums/topic/21792-falken-fk451s/#findComment-462774
they are alright for performance, only noisey and have bad ride quaility.
they are all the same as they made with same compound, size won't affect the quaility.
The only reason most ppls with big rims having them, is because they are the cheapest performance tyre which have LARGE range of size.
most of the brand only sell their TOP of the range performance tyre in low profile 17/18 or even 19. but falken have all of them even with the lowest range
stock rim should be 6"5, fit 225/50/16
but i heard some one fit a 245/45/16, not sure though.
hope that help
https://www.sau.com.au/forums/topic/21792-falken-fk451s/#findComment-463264
Well Fk451 are not too bad but have you ever thought about the ST115s? These are basically street Azenis rubber that have a soft compound but are great at giving you feedback and stick really good too. There not that much more then the FK451 but are heaps better when it comes to handeling and they have very little tyre noise too. Hope that helps mate.
https://www.sau.com.au/forums/topic/21792-falken-fk451s/#findComment-469892
Really good JimX. Wet or Dry, i have found these tyres extremly good. Even in the wet they have the same amount of feedback as in the dry. Heaps better then the FK451. Only down side is that they might wear abit qiuk due to it being a softer compound but that's the price you pay for having good tyres.
https://www.sau.com.au/forums/topic/21792-falken-fk451s/#findComment-472153
I'm used to having soft tyres. I need to replace the rear on my motorcycle every 6000km or so @$300 a pop. I think I'll try the ST115's, especially since they were cheaper than the FK451's (unless the shop guy got the prices wrong when I rang).
https://www.sau.com.au/forums/topic/21792-falken-fk451s/#findComment-472346
Is $280 per tyre for ST115 in 255/40/17 a good price? That's what I got quoted from my local Falken tyre shop. The ZE326's and FK451's were both $320 each. Is there anyplace in Sydney that can do better than $280 for the ST115's?
https://www.sau.com.au/forums/topic/21792-falken-fk451s/#findComment-472516
I think I stuffed up, I think I confused the prices I got for the ZE326 and ST115 around the wrong way. Which would mean this place sells the ST115's for $310. In that case, where can I get the ST115's for $280 in Sydney?
https://www.sau.com.au/forums/topic/21792-falken-fk451s/#findComment-473312
For anyone that's interested, I found out why ST115's have low road noise. According to Falken's American site, the ST115's have "Base tread rubber compound contains micro vacuum capsules that literally suck up road noise". I'm assuming that this also means less rubber hence they wear out quicker.
https://www.sau.com.au/forums/topic/21792-falken-fk451s/#findComment-483291
Going off reports on both I don't think they are worth the price difference. But this is only a rough judgement call based on other people's opinions, there's no way to tell unless you've test-driven both yourself. If I had lots of spare money I'd buy the best tyres I could but I can't so I'm going for the ST115's or FK451's (probably the former).
https://www.sau.com.au/forums/topic/21792-falken-fk451s/#findComment-492475
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
