Item: Defi Gauges, Heads Up Display and Control Unit 2
Age:New and used
Condition:excellent
Price: Stated below
To Fit: (What car)
Contact:0412 005 791 or PM me
Comments: Not needed anymore. Price is negotiable. Not entirely sure what these items retail for at the moment so throw me some offers.
Hi,
I have some Defi goods for sale. The gauges are unused and still in boxes, while the control unit is used but has all the required wiring,
1. 60mm Blue face Defi Boost gauge ($200)
2. 52mm Oil temp gauge ($150) (Not BF gauges)
3. 52mm Oil pressure guage ($170) (Not BF gauges)
4. Defi Control Unit 2 ($70)
5. Defi Heads Up Display ($300) -> This display can be hooked up with the gauges to show data such as boost, oil temp, oil pressure etc. It also shows Speed and perhaps Revs.
Price is negotiable. I will sell the whole lot at a cheaper price. Throw me some offers.
Located: Eastern Suburbs Victoria
Reason for sale: No longer needed
Thanks,
Jon
Edited by silkishuge
Hey mate..
Had a look at the Defi HUD.. What is needed?.. I assume that you need some sort of Defi control unit?.. Do you need the specific gauges for it to be shown in the HUD? What else is needed?
Hey mate..
You will need a Control Unit and if you want to display other information, you will also need to purchase the sensors separately. Alternatively, you can buy the oil pressure and temperature gauges, which will also have the sensors you need. You will find that buying the sensors separate, will cost nearly as much as buying them with the gauges.
Jon
pm sent for control unit & boost gauge
Control Unit 2 and boost gauge have been sold.
Thanks for interest.
Alot of interest in the oil temp and oil pressure gauges but awaiting someone who has told me he wants the item over the phone but has not PM me yet to identify himself.
PRICE DROP on HUD -> ($230)
Thanks,
Jon
If you look at the price in Yen, at todays conversion would still require about $180 for the oil temperature gauge and $250 for the oil pressure gauge.
Jon
Jon
Defi HUD is now sold.
Items remaining are the oil pressure and oil temperature gauges.
Thanks,
Jon
are the oil temp. and press. gauges new?comes with all the required sensors,wirings etc?oh..and what color does it light up?do have the model of it?
Edited by GReddy_ES8
The oil temperature and oil pressure gauges are new and have never been installed in any car. They come with all the required sensors. I do not know what colour they light up because I have never used them before.
This is taken from an advertisement of the gauges:
Defi-Link Meters are electronic gauges which are high response and refined design.
Defi-Link Meters need to be connected to Defi-Link Control Unit II.
Up to 7 gauges can be connected and controlled by one Control UnitII. The name of the connection system is "Defi-Link System." Defi-Link System allows gauges to be attached to Defi-Link Control Unit II with a single "DAISY CHAIN" wiring system. Each gauge has two LEDs. One LED illuminates when the gauge pointer exceeds a warning value which is discretionary with the Control Unit II. The other LED illuminates when the gauge pointer exceeds a past maximum value.
FeatureNote
Gorgeous Opening mode: During the opening mode, wire disconnections, short circuits, and serial errors are checked automatically. When errors are found, LEDs light up in order.
Full-lineup: boost(for turbocharged and supercharged engines), intake manifold pressure(for natural aspirated engine), oil pressure, water temperature, oil temperature, fuel pressure, exhaust gas temperature and tachometer. White and black gauge
dials are available. A bright transparent green gauge dial and a red instrument needle pointer are used in the gauges to increase visibility at night and in low-light conditions.
The scale of 4 1/2" gauges is compressed to acquire great visibility and ease of use. Wide-angle scale is used at the idling range 0~1,000RPM. The scale is fitted to recent engine power band and linear scale is used from 3,000RPM to 11,000RPM.
NEW Regular Position Bezel is attached to 52mm gauges. The bezel enable user to find a subtle change in car by setting
the position of the red triangle depending on the driving situation.
Driving data can be stored and can be replayed up to 3 minutes.
Double Warning function by a meter's LED lamp and a beep
If Defi-Link Indicator(sold separately) is connected, it blinks when any of connected meters' warning LED lights.
Defi-Link Indicator can be connected with each meter.(Defi-Link Indicator is standard option for 4 1/2" and 3 1/8"
Defi-Link Meters.)
Differential pressure between fuel pressure and turbo can be shown if both of fuel pressure meter and turbo meter are
nstalled.(*3)
Defi-Link Control Unit II or Defi-Link Control Unit is necessary to operate Defi-Link Meter.
Defi-Link Meters are applicable to 12V vehicles only.
Hope that helps.
Jon
  • 3 weeks later...
  • 3 weeks later...
    • I'm thinking that this is such a small part of the problem that you could easily forego the vac pump and just achieve 90% of what you need, which is keeping the gate open when off boost. It's not as if there are not already techniques to keep a gate fully closed under boost. After all, you have boost. Just use a wastegate actuator that will allow you to apply the boost on the appropriate side, just like every external gate out there.
    • Heres another fitment photo. redrilled the pattern to 5x112, and threw my audi´s rims on. had to touch the upper control arms with grinder, because the "sharp corner" was sticking about 2-3mm on the tire path. i have the "fender lip" mostly cut off, otherwise these (too) would contact with it. 20x9.5 ET25 rear    265/30 20x8.5 ET20 front    255/30 they are temporary, and look too big for the chassis. searching for 19s to it.
    • From experience, it will come back to bite you haha.
    • Background: my BMW 225i hatchback (rebodied MINI/X1) came with 3x RE003 and 1x Goodyear Asymmetric something. The RE003 roared and slid around, the Goodyear side was quiet and grippy. Definitely my car was thrashed before it got sent to dealers. My brother also got RE003 all round on his old VA WRX STI, I wasn't impressed with them, car was loud so can't comment on noise. Anyway, Hankook stopped making/updating V12 Evo2. So bought S1 Evo3 runflats. Great daily duties tyre and not that harsh ride. Tyre reviews site/youtube rated them as best stopping in the rain and I believe them. Next set, Goodyear Asymmetric 5 non-RFT. It beat PS4 in tests and is like $100 cheaper, so put them on. Great tyre, more grip then S1 Evo3 but a tad noisier as expected, still rocking them. Next set I am looking to go runflats, probably the new Hankook Evo. Although the new Pirelli PZ5 did well in tyrereviews test. Or go Goodyear Asymmetric 6 which was top tyre last year. The V12 Evo2 on my gen5 Liberty GT wagon did great in cold condition (drove to snowy mountains for a day so my husky can feel his ancestor's roots). Super impressive performance for $120 each lol. Never skimp on tyres, brakes, suspension. There's old pics of my R31's crappy random brake pads bending in the caliper at Oran Park track day somewhere around here. Anyway, my 2 cents.
