Item: Defi Gauges, Heads Up Display and Control Unit 2
Age:New and used
Condition:excellent
Price: Stated below
To Fit: (What car)
Contact:0412 005 791 or PM me
Comments: Not needed anymore. Price is negotiable. Not entirely sure what these items retail for at the moment so throw me some offers.
Hi,
I have some Defi goods for sale. The gauges are unused and still in boxes, while the control unit is used but has all the required wiring,
1. 60mm Blue face Defi Boost gauge ($200)
2. 52mm Oil temp gauge ($150) (Not BF gauges)
3. 52mm Oil pressure guage ($170) (Not BF gauges)
4. Defi Control Unit 2 ($70)
5. Defi Heads Up Display ($300) -> This display can be hooked up with the gauges to show data such as boost, oil temp, oil pressure etc. It also shows Speed and perhaps Revs.
Price is negotiable. I will sell the whole lot at a cheaper price. Throw me some offers.
Located: Eastern Suburbs Victoria
Reason for sale: No longer needed
Thanks,
Jon
Edited by silkishuge
Hey mate..
Had a look at the Defi HUD.. What is needed?.. I assume that you need some sort of Defi control unit?.. Do you need the specific gauges for it to be shown in the HUD? What else is needed?
Hey mate..
You will need a Control Unit and if you want to display other information, you will also need to purchase the sensors separately. Alternatively, you can buy the oil pressure and temperature gauges, which will also have the sensors you need. You will find that buying the sensors separate, will cost nearly as much as buying them with the gauges.
Jon
pm sent for control unit & boost gauge
Control Unit 2 and boost gauge have been sold.
Thanks for interest.
Alot of interest in the oil temp and oil pressure gauges but awaiting someone who has told me he wants the item over the phone but has not PM me yet to identify himself.
PRICE DROP on HUD -> ($230)
Thanks,
Jon
If you look at the price in Yen, at todays conversion would still require about $180 for the oil temperature gauge and $250 for the oil pressure gauge.
Jon
Jon
Defi HUD is now sold.
Items remaining are the oil pressure and oil temperature gauges.
Thanks,
Jon
are the oil temp. and press. gauges new?comes with all the required sensors,wirings etc?oh..and what color does it light up?do have the model of it?
Edited by GReddy_ES8
The oil temperature and oil pressure gauges are new and have never been installed in any car. They come with all the required sensors. I do not know what colour they light up because I have never used them before.
This is taken from an advertisement of the gauges:
Defi-Link Meters are electronic gauges which are high response and refined design.
Defi-Link Meters need to be connected to Defi-Link Control Unit II.
Up to 7 gauges can be connected and controlled by one Control UnitII. The name of the connection system is "Defi-Link System." Defi-Link System allows gauges to be attached to Defi-Link Control Unit II with a single "DAISY CHAIN" wiring system. Each gauge has two LEDs. One LED illuminates when the gauge pointer exceeds a warning value which is discretionary with the Control Unit II. The other LED illuminates when the gauge pointer exceeds a past maximum value.
FeatureNote
Gorgeous Opening mode: During the opening mode, wire disconnections, short circuits, and serial errors are checked automatically. When errors are found, LEDs light up in order.
Full-lineup: boost(for turbocharged and supercharged engines), intake manifold pressure(for natural aspirated engine), oil pressure, water temperature, oil temperature, fuel pressure, exhaust gas temperature and tachometer. White and black gauge
dials are available. A bright transparent green gauge dial and a red instrument needle pointer are used in the gauges to increase visibility at night and in low-light conditions.
The scale of 4 1/2" gauges is compressed to acquire great visibility and ease of use. Wide-angle scale is used at the idling range 0~1,000RPM. The scale is fitted to recent engine power band and linear scale is used from 3,000RPM to 11,000RPM.
NEW Regular Position Bezel is attached to 52mm gauges. The bezel enable user to find a subtle change in car by setting
the position of the red triangle depending on the driving situation.
Driving data can be stored and can be replayed up to 3 minutes.
Double Warning function by a meter's LED lamp and a beep
If Defi-Link Indicator(sold separately) is connected, it blinks when any of connected meters' warning LED lights.
Defi-Link Indicator can be connected with each meter.(Defi-Link Indicator is standard option for 4 1/2" and 3 1/8"
Defi-Link Meters.)
Differential pressure between fuel pressure and turbo can be shown if both of fuel pressure meter and turbo meter are
nstalled.(*3)
Defi-Link Control Unit II or Defi-Link Control Unit is necessary to operate Defi-Link Meter.
Defi-Link Meters are applicable to 12V vehicles only.
Hope that helps.
Jon
  • 3 weeks later...
  • 3 weeks later...
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
