that area is East Perth... very nice places in there and some wicked landscaping and lighting around there :/ wanted to stay for longer but I was getting to much traffic on the bridge and it was starting to wobble all the time..
going out again tomorrow to see what I can get...
however that can be in the June thread :wave:
  • 4 weeks later...
