Hey,
Thinking of importing a modified R33 GTR but I'm just wondering whether it will be able to be complied easily or not. The cars I'm looking at have been rebuilt using forged pistons etc, have pretty much everything aftermarket to the engine possible as well as some aftermarket body parts...
All aftermarket parts have to be removed yeah? So what sorta costs are involved to get something like that complied? What parts would they allow to slip through and what would they crack down on?
Cheers,
Chris.
https://www.sau.com.au/forums/topic/218002-importing-modified-vehicles/
Yeah it is not advisable to import fully modified cars (unless for race use only) as the compliance work is usually either too expensive (don't think the compliance shop will remove all those special parts for free :() or just plain too much hassle for compliance.
If you want something you can register, look for something with only basic mods that can be easily returned to stock, as the car must be in factory specification (or the equivilent to it) to get compliance.
If you want it purely as a track car (and I mean purely, as in the chassis can never be complied and therefore NEVER registered) then you've pretty much got free reign over what mods it has, although last I heard you need to own a CAMS L2S licence to import a race only vehicle.
The letter of the law is that the compliance workshop must bring the car to factory standard and DESTROY all aftermarket parts.
Does every workshop do this? Um.....no.
Aftermarket front mount intercoolers usually cut holes in the body of the car, which is considered accident damage, so these technically can't be complied. We knock back these cars all the time, but some backyarder compliance workshops might do them.
If you send us some photos of the car, we can let you know if we'd comply it, but every workshop will be different depending on the amount of risk they want to take. We've got 20 plates on our schedule, so if DOTARS shuts us down for complying a car like that (they audit vehicles sometimes), that'd be a huge loss to us. If some guy's got just 1 or 2 plates on his schedule, his risk is just those 2 models on his RAWS schedule, so he'd probably be more likely to take the risk.
Also, RAWS workshops have a quota of 100 plates per year, per workshop, so since we usually fill our quota, it doesn't make sense to take the risk. Guys with 1 or 2 models on their schedule probably don't fill their quota, so they'd be more desperate to get the work.
Of course, everyone knows this, so people will charge accordingly. We don't charge to remove/reinstall parts, but I've heard some workshops do.
basically send photos and as much info as you can to the compliance workshop and get them to lay out all the charges upfront.
hope this helps,
david @ Carizma
also, don't forget you also have to get a RWC on top of this (if in VIC, other states not really sure how it goes).
Hey,
Cheers,
Chris.
Cheers for the info. Basically the car has aftermarket turbos, injectors, computer, air filters, bonnet, front bar, front fenders, sideskirts, rear pods, exhaust, wheels, front and passenger seats, suspension etc. How much for compliance for this? Model is 1997 R33 GTR.. Rough quote will be fine.
  • 4 weeks later...
Just looking at that list, I doubt our workshop would take that job. Might find a backyarder who'd do it, someone who isn't filling their quota.
Yeah, as IronChef said, getting it registered is going to be tough. It seems like the state transport departments are cracking down on modified imports a bit also, just from our experience these past couple weeks.
And that's just VicRoads...I'm sure he has plenty of good stories about Regency Park, well probably not 'good' stories.
the only way to do a 'personal import' is to live in the country overseas for at least 12months and own the car there for at least 12 months then bring it back with you to aus. not feasible at all unless you currently live in japan. personal imports I would say count for less than 1% of car imports.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
