Hey guys,
As most of you are aware this new option that Just-Jap provides is a fantastic solution to dodge the hacking of the drivers side engine bay that you have to do for other intercooler installs. Which is very illegal if you have a R33 with Airbags.
However the question that i raise now, even though there is NO cutting of a whole in the engine bay for these new kits, is it legal to have a FMIC mounted on a R33 with airbags? or is it still illegal to even have a FMIC mounted cause it may interfere with airbags still?
Im really keen on these kits but still unsure on how legal these are.
P.S i would run the stock airbox so the FMIC would act as my 1 intake mod :P
Thanks
https://www.sau.com.au/forums/topic/218034-cooling-pro-stealth-fmic-legal/
As u said in Vic you are allowed an intake mod, so the FMIC would be legal. Do u know where the airbag sensors are located ? If u dont need to relocate the sensors then it should be ok. Speak to the regulatory authority in your state. Vicroads?
EPA rule states ONE intake mod
So Pod OR FMIC
There is a massive full detail EPA thread in the Vic section
http://www.skylinesaustralia.com/forums/Ep...Th-t156269.html
Cheers.
I fully understand these intake EPA laws and i intend to follow them, however im asking whether having a FMIC on an R33 with airbags is legal or illegal (when using Just-Japs new intercooler kits that you dont need to cut holes for)
these puppies http://www.skylinesaustralia.com/forums/Co...er-t209304.html
or is it still illegal cause it play an impact on airbags when hit from the front ?
cheers
Probably LOL but would u want to run a pod?
I think id prefer the stock air box.
Quiter and cooler air :laugh:
Yeah i have a K&N panel filter at the moment. If i was to go to POD then i would most likely build a new box from fibreglass or something incorperating the factory snorkel etc. Not really thinking too seriously bout that at moment tho.
With the R34 SMIC ya can barely tell the difference from the outside (of course duh) but even when you look under the car, the drip tray plastics hide it all anyways and the intake ducting makes it hard to see too. :(
All good for me tho. lol
Hrmm...
Now i have to make the decision whether to get one of these stealth Just-Jap kits or run a R34 SMIC.
Mods:
Exhaust (3")
BC (12psi)
what would u do ?
Personely I would go with the FMIC. It is legal on your car and has a large serface area for cooling, with pretty good flow and little persure drop.
I have a FMIC in the stealth style (made it myself) and I painted it black for the extra stealth look.
But thats just me, SMIC is still a very good option.
Did you notice a difference when fitting the 34 cooler? or much of a muchness from the stock.
They go for about $150?
Who did your pipework ? How big is ur core ? 600 x 300?
I have a 600 x 300 x 70 core already but i would need the pipework made up to run back underneath the core, but doing this i am also affraid if will hang to low below my front bar. Hence why im asking what size ur core is.
Does ur underneath pipe hang lower than you front bar?
My core is a HKS 600 x 300 x 70 and I used BLITZ piping and welded the angled return onto the side of the cooler myself at work, on their time. :(
It all went together pretty easy.
I have an M-SPORTS front bar and it covers the piping fine. The M-SPORTS bar is only a little lower than a stock bar. The stock one should cover the piping as long as you mount your cooler to the underside of the bumper re-enforcement.
Just a quick question.
Why didn't you hide the return pipe behind the fmic, instead of coming back under it.
I think it would look a lot neater and make fark all difference to the flow of the cooler.
EAS Performance did all my piping and fabrication work on my car. Contact details below.
Old Setup:
New Setup:
I have a m sports front bar too....my core is a little different to yours but. outlet is lvl with the bottom of the core.
so if i made an underneath pipe like urs the 180 bend would be alot sharper. I called up a few mobs and they wanted something like 200-300 bucks for the pipe... so i figured it wouldnt be worth it.
Extra couple hunder and i can get a new kit :S
Plus 200-300 bucks was step if it were to hang down and get caught on every speed bump!!
Old Setup:
New Setup:
How much u recon EAS would charge to make a pipeup like ~R33AzzA~'s.
All workshops i called up said about 200-300 which i found pritty step, but then they told me it was alot of work involved :S unless they just didnt wanna do it hahaha
It just seems there isnt enough room to run it behind / under like ur suggest and seems it would hang down alot.
You can make your own piping, buy some exhuast bends (mandrel) and some tube, tack it together and get someone to finish welding it.
It might be mild steel but its easy to do, and not to expensive. If you need tube I can supply some to you as I have a heap of 2.5 inch tube at work.
Mandrel bends are avalible at truck bits for around $10 bucks a bend (don't quote me on price).
Thoughts on mild steel piping? Painted on the outside of course.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
