wait 'til a Viet person complains to VicRoads about your plates and they cancel 'em :D
Well... thing is
A) This is australia. if it dont mean a damn thing in english (aside from 'ben is one cool cat') then theres no legal precident
B) The spelling is different... as kietz noted earlier, im not viet so officially "i have no idea about what you're all talking about"
C) Nobody has complained in the last 12 yrs of me using this nick
D) I'm not in victoria (praise allah)
Obama 08' nizzlz.
-D
hey dohmar u play warcraft frozen throne? dota much? lol
nope, i only play WoW and the occasional FPS like SoF2 or F.E.A.R... clocked HL2, Doom3, Quake4, Fear, Fear Next, Sof1,2... never was into CS or Halo... im more into realism.... operation flashpoint was my fave
-D
    • Apologies, while id like to put the MAF as close to the TB and relocate the recirc, this may be too much work. Will most likely end up just putting it on the original AFM spot ( onto/next to the airbox ).  Was going through nistune, found a pretty nifty doc on this. Nistune MAF Notes. Also, i was looking through the bay, and there seems to be a tube/line connected from the A/C to the intercooler piping ( Between the smic and the recirc), what does this do as the crossover fmic piping doesnt have any connection? plumbing? not sure what you call it but the nipple thing ahah.  Also, been reading up more about crossover fmic in regards to the legality of having the hole drilled for the piping, this would most likely need to be engineered right?
    • My advice is if you need a big build done do it in Japan. The yen rate is so favorable and there are shops that can be genuinely trusted and not micromanaged/carefully monitored every step of the way. Garage Yoshida is obviously my preferred option but they're so busy these days and all interaction with new customers has to be mediated through BBL/Toprank now.
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
