eh anyway after alot of screwing around i'm putting my belt back on my car.. now the only problem i have is lining it all up.
I've attached a few pictures showing the gears lining up with the backing/key hole.. i just want someone to verify that that's where u line these little nubs up at.
The engine is at TDC
Also on the cover for my exhaust cam gear (vac holder thingo) theres a white mark, which lines up with the mark on the exhaust gear.. which i'm assuming is all good.
Other question i have is where do u line the marks on the timing belt up with? do they line up with the white marks on the backing plate behind the gears(and the slot on the bottom one) or somewhere else? (i cant use the ones i marked on the timing belt because i'm wondering if it may have skipped a gear)
Also my exhaust cam seems to be a tiny bit more advanced than the other one.. they're normally exactly opposed right? i can twist it back a tooth by hand
Edited by GTAAAH
https://www.sau.com.au/forums/topic/218038-is-this-right-timing-belt/
looks all good to me , Make sure your tension is correct, i usally roll it over a few times then re check it, usally thae marks on the belt can be matched to the marks on the gears to make it easyier but they dont always line up, so use the marks on the motor.
hmm so to line it up without markings would i just make sure the idler side is real tight and then tighten the tensioner side so it's tight as well, or is it still possible it can be a tooth out on the idler side and i'll need a new belt? (this one is only a few thousand k's odl)
Edited by GTAAAH
OK that's all done but 1 other question i have.. does the engine need to be set to TDC when your putting the CAS on? i marked it and (altho the markings have faded) think it's real close to where it was.. but i'm just wondering if the positioning of the engine will make a difference? Also this thing you can adjust left and right to retard/advance timing right?
ty
ah yeh i have the half moon key slotted in ok, just wasn't sure, what your saying makes sense because obviously i didn't stop the engine at tdc hehe, bit of a brain fart there.. car will be all back and going tomorrow hopefully after hogging the garage for 4 months hehe
and the belt was changed as part of my buying deal, just before i bought the car and hasn't more than 2000km's on it, it looks fine so i see no need in replacing it
Edited by GTAAAH
ugh re-using timming belt's
stdish rb26 rebuild $4000 +++
gate's belt $120
i know which one i'd choose, who's to say you have got the belt going the opposite way to which it was worn...
STD belt from nissan cost me about $95
peanuts really :D
k it's all back together and car seems to run fine.. bit of a ticking sound i can hear from outside car or bouncing off walls.. i havnt had this thing on in ages but think that was there before hand.. how noisy are the injectors in these things? i'm thinking it's that.. anyways hopefully i'll drop by a mech tomorrow and get them to take a quick look, then it's clutch replacement time
thx for the help guys (in the other thread too)
The injectors are quite noisy, as are the solid lifters even when shimmed to factory tolerance. You can isolate the noises by giving the engine a race while listening. You will notice the injectors cut out on engine decelleration. If the loudest noise goes away in this situation then its the injectors :domokun: Another option is to use a proper stethescope or just a screwdriver on the suspect and the other end pressed on your ear.
By the way engine oil wont change lifter noise in a Rb26, as mentioned they are a solid lifter arrangement and do not require hydraulic pressure to operate. If they are noisey the only way to quieten them is to re-shim.
Hope this helps,
Deren
Ah thanks godzilla, the noise stays constant through deceleration (i didn't think it would totally cut the injectors on backoff) so i guess it must be the lifters that are the problem.. which isn't really a problem after all. thx for the help
    • Dang. I love the little 'oil used' bingo card on the side.   🤣  Well, now they can use a box and an oil-filled goon.
    • Many many moons ago, I was chatting with Andy Wyatt, about his auto ignition tuning. One of the HUGE things he said to me, when tuning for power, right where you hit peak ignition timing for your max torque, dramatically increases NOx emissions. He was finding in testing, particularly on engines you could advance timing beyond peak torque, that backing the ignition timing off a couple of degrees only made for a small drop in torque (compared to if you keep backing it off further the same amount of degrees) but dramatically reduced NOx emissions. I'd say targetting for 14.7, and he's even mentioned in some scenarios going slightly leaner, and pulling a few degrees of IGN timing will help pass for emissions quite a lot. However, who tunes an RB for emissions
    • The main stuff from.Vibrant I see is more their intercooler piping, and everyone raving about their clamps, but when I looked it was about $150 per clamp... I was a bit   I also thought the public price SP had up was high. As Mark said, a normal exhaust shop can fab them. It was many years ago that I had a full exhaust built, but for a full turbo back exhaust, and 2 custom built mufflers, plus a high flow cat, was about $1,100, and that was fully installed, drive in, drive out. I believe SP was about $900 for 2 mufflers, just supplied   These days, I just buy the material and built it myself, because I need to stretch my $$$
    • I'm pretty sure if it's considered a gasoline powered vehicle you have to do certification against a fixed, very expensive certification fuel.  If you add two precats and then replace the main cat with two cats back to back you can get an RB26 to do 0.24 g/mi HC, 1.6 g/mi CO, and 0.3 g/mi NOx on the FTP-75 drive cycle. Found this out courtesy of California's laws at great expense. Divide by 1.61 to get g/km. So even with extra cats + precats you're blowing past the NOx limit by probably 2.3x. Probably the only way to get an RB25 or RB26 to meet euro 4 purely from an emissions per km standpoint and not durability/OBD2 requirements is retrofit at least intake side VVT, clearance the pistons to allow the full 50 degrees of advance so part throttle EGR can be maximized, and change the wastegate control from conventional 7 psi spring for example to one that is always fully open if the wastegate line is at 1 atm or higher and only close it in response to vacuum. See BMW's N54 engine as a reference for how this works. You would need to find space for a vacuum tank to function as an accumulator in this system. That way you can avoid any heat loss to the turbine as much as possible during cold start to heat the catalyst faster. Then find some way to eliminate as much as possible cold start enrichment to light off the catalyst rapidly. Maybe secondary air injection if there's no way to avoid cold start enrichment. Close coupled catalysts in the downpipe are probably necessary. I would also probably swap to EV14s, pick something with the correct spray targeting + dual cone pattern for the intake manifold you're using. EV1 style injectors to pass anything resembling modern emissions requires a very annoying air assisted injector system to break up the droplets at part throttle/idle which still doesn't work that great compared to just having smaller droplets from the injector to begin with. Realistically, you're probably going to be financially ahead if you just pay the fines instead. Or don't drive it into the city center. There's a reason why Nissan never bothered to even attempt certifying an RB for CA/US emissions. The VG30 needed external EGR on top of NVCS to pass in the 90s. Doing all of this work is also distinctly expensive and you're going to struggle to find anyone who is remotely interested in helping.
    • I remember those, people use to steal them to make bongs.....
