34gtr Nismo Mfd Installation
If i used a cooling system pressure tester, would it show me a leak with the head gasket? Ive used one before to chase down a leaking coolant hose. Not sure if this will work on the oil-cooler warmer.
Nice, i like the sound of 600.
Hi all, suspect this is a common problem. I think I missed 4th gear a bit when I shifted down from 5th. Now it grinds into 4th with the downshift. Is it the sychro and what do I need to replace when I open the gear box up? added a photo of my new titanium intake I just installed and built. 👍💪
They're all essentially the same**. Although you have to differentiate between "block" and "bottom end", because Neos have different pistons and rods to vanilla 25s. I won't speak to whether there were oil pump drive changes to take into consideration, as that can be fixed anyway.
Car would be very knock limited on pump 98 fuel, this is also why lots of old school turbos has such a massive turbine end to drive a small compressor. Overall a decent result for pump fuel,
