i guess the hipermaxones has aluminum body, which is a lot lighter.
design makes a lot different, if the HKS one has a reervior tank which allow more oil in the suspension, it really worth the different.
has tein HA on my car, very good handling but VERY hard, don't want to drive it after having a nice & full dinner, and GF complain that it will makes her breast fall down 10 years eariler! :P
i guess HKS will have more balance between handling & ride quaility
G'day Maxx,
Hoping you could advise. I too have a set of Teins, but they are the non-adjustable NR series. Be that as it may, they're still bloody stiff, as in I can feel every ripple on the road. But not only that, it makes quite a disconcerting thud on every bounce. Do you get that as well? Just a little worried on what I've just done to the car. :(
Thanks!
Guest gtst88
the tein Flex are really cool considering that you can adjust the hardness of the shocks in car .. which is sweet !
thanks for your reply guys ..
my friend has TEIN HA in his DC5 .. they are a lil hard, but when the car corners its so nice ..
any other brands i should look at besides hks, tein and ohlins ?
thanks again guys !
cheers ! drift safe now ..
from what i know there are different types u can get .. things that can be adjusted depending on which one u get are .. camber .. height .. damper ... anything else??
also keep in mind that most of these shocks on the coil overs are actually european made and most are from the same manufacturer ie bilstein koni etc .. u are really just payin for the specs ... similar to way turbos are ..
I have Tein HAs and absolutely love them. On the softest setting I actually found it too soft for my liking. But that I guess is personal preference. It's nice having the ability to adjust them exactly to my liking. The difference in the cars handling is incredible compared to the standard suspension (mind you, I have a gtst, not a gtr) On the hardest setting, you will get a head ache, a sore neck, and a sore back within 10 minutes of driving. Save that setting for the track.
If you prefer the ride feel of a commodore, then steer clear of the Teins though as the softest setting seems to be too hard for a lot of people.
r Hey i got HKS suspension - i sound like a chimp, but, how do i adjust the damping of them? I got the tools too :D
my rear shockers stick out into the rear parcel. is that the same with all u HKS doods?
If i set the damping softer, when i go over bumps, will my wheels (less than than a finger width from the guards) now hit my guards?
    • Last year I got a set of MCA street coilovers for my turbo Forester after my son hitting a concrete gutter/wall on a small bridge causing the whole drivers side suspension to get bent because the rain just made the car slide out I love them, I think they were $2400. even had a hiccup of have the wrong hub configuration (my fault) so got onto MCA and they sent the correct shock ends overnight parts from QLD, for free!  I was very impressed with their customer service and quality of the product
    • They've had some weird failures on their brake actuators. One of them was because they added some kind of lubricant to the factory fill brake fluid that aftermarket brake fluid didn't have so it would affect the seals. Another was just mysterious, probably internal corrosion or something eating away at Prius brake actuators. Parts alone for those are a few thousand USD so not a cheap fix.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
