i am relatively new to the Skyline scene but not new to blowing up gearboxes in turbo cars due to too much power.i am driving a 1994 gts-t with the rb25det engine,its an auto and as far as i know its standard.i am wanting to add some mods to what i currently have(full exhaust,hks pod filter,hks blow off valve and a turbo timer as far as im aware).how much power can the standard auto gearbox handle on a daily driver? also what kind of mods can be used to prolong the life of the gearbox? i am wanting to get up to around 400bhp at the flywheel and am checking out before i go and wreck the gearbox.
thanks in advance :(
Somewhere like Yarra Valley Autos or KEAS would be the places to talk to, very good in the business
All sorts of upgrades around i believe.
I dont think the stock auto will hold 400hp @ the fly to be honest. For a while maybe, but it will die so best get it done while you can.
speak to RCHOO (pm if you like)
he has blown two auto rb25det boxes
maybe he can shed some insight on the cause of failure
might be some helpful info too, he was getting one of them rebuilt too
Hmmmm.... The BOV and Turbo timer add eleventy billion rwkw!
stock box with a shift kit and trans cooler will handle up to 300rwkws for a while.
so if you only want around 230 rwkws, it should be fine, with just the shift kit and trans cooler.
if it starts flaring get MV autos to build you a custom box with high stall, which is what i have.
currrently running 320rwkws with 24 psi thru a gt3582r/iw daily driven.
I was told by MV also that the stock box will handle around 260rwkw in stock form, but mine with 235rwkw rides the 2nd gear band during the change for ages so a shift kit and tranny cooler are next on the list, and if I can afford it I will get the higher stall option aswell.
He said if I was going for more power then I would have to upgrade the box as it does not have enough clutch surface area in the box clutchpacks to hold onto much more power.
The 235rwkw I have roughly equates to 420hp odd at the flywheel.
Dave
I have gone through 3 autos before i finally had mine rebuilt
first 2 died with simply an rb25 pushing 250rwhp and they had oil coolers. boxes were a bit iffy though. I bought a good box though with only 40xxx kms and it lasted 2 days with 330rwhp and it had a KEAS full Manual kit. Now have my current box which has been rebuilt and it seems happy with 370 runnign through it. I was told the stock box should hold up to 350rwhp with a good oil cooler and shift kit, but i dont believe that lol.
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 馃槩
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
