i am relatively new to the Skyline scene but not new to blowing up gearboxes in turbo cars due to too much power.i am driving a 1994 gts-t with the rb25det engine,its an auto and as far as i know its standard.i am wanting to add some mods to what i currently have(full exhaust,hks pod filter,hks blow off valve and a turbo timer as far as im aware).how much power can the standard auto gearbox handle on a daily driver? also what kind of mods can be used to prolong the life of the gearbox? i am wanting to get up to around 400bhp at the flywheel and am checking out before i go and wreck the gearbox.
thanks in advance :(
Somewhere like Yarra Valley Autos or KEAS would be the places to talk to, very good in the business
All sorts of upgrades around i believe.
I dont think the stock auto will hold 400hp @ the fly to be honest. For a while maybe, but it will die so best get it done while you can.
speak to RCHOO (pm if you like)
he has blown two auto rb25det boxes
maybe he can shed some insight on the cause of failure
might be some helpful info too, he was getting one of them rebuilt too
Hmmmm.... The BOV and Turbo timer add eleventy billion rwkw!
stock box with a shift kit and trans cooler will handle up to 300rwkws for a while.
so if you only want around 230 rwkws, it should be fine, with just the shift kit and trans cooler.
if it starts flaring get MV autos to build you a custom box with high stall, which is what i have.
currrently running 320rwkws with 24 psi thru a gt3582r/iw daily driven.
I was told by MV also that the stock box will handle around 260rwkw in stock form, but mine with 235rwkw rides the 2nd gear band during the change for ages so a shift kit and tranny cooler are next on the list, and if I can afford it I will get the higher stall option aswell.
He said if I was going for more power then I would have to upgrade the box as it does not have enough clutch surface area in the box clutchpacks to hold onto much more power.
The 235rwkw I have roughly equates to 420hp odd at the flywheel.
Dave
I have gone through 3 autos before i finally had mine rebuilt
first 2 died with simply an rb25 pushing 250rwhp and they had oil coolers. boxes were a bit iffy though. I bought a good box though with only 40xxx kms and it lasted 2 days with 330rwhp and it had a KEAS full Manual kit. Now have my current box which has been rebuilt and it seems happy with 370 runnign through it. I was told the stock box should hold up to 350rwhp with a good oil cooler and shift kit, but i dont believe that lol.
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
