"1978 Datsun C210 rare vehicle , completely road registered wit Matching chasis , transmissionan and engine numbers rego expires few days no defects, new tyres on all 3 , bent cross member on the front still barley drivable with a magna wheel upfront
motor is in ok nick , same as trans and diff
will have pics in few days
sooo $300 ?
contact pm me
p.s i sold this car to ricebanger for 2.5K not long ago
https://www.sau.com.au/forums/topic/218064-1978-datsun-c210-rare-vehicle/
my new car a clean as EK civic just got bricked
maybe a trade for the skyline for panel fixage , just need a bonnet undented some how then resprayed, insruance said they would cover it tough and make the person pay but cant reley on em
by the way with the front pic of the wheel how its in thats due to a bent cross member and due to a magna wheel so ya
i was told by the previous owner that the carby and motor and diff and gear box has been rebuilt + new gaskets all around , i belive that even a mechanic said it looks like it but ive had the car for 10K KM so ya its gone down the drain still doesnt blow smoke etc
  • 3 months later...
