hey all as per topic title, can the nsw police force bring up details of previous defects for our cars in their police car computer thingy? or do they just bring up offences? i dont know someone explain it to me, the other night i got pulled over again and the copper asked me has someone issued me a warning for the exhaust being too big i said yeah i got a defect for it (although i had cleared it already) and said they have given me 14 days since last thursday to fix it, and he said thanks see you later, do i assume from this that they are unable to bring up defect records?
  • Replies 69
still then i dont get how this guy let me off with my exhaust.... LOL its back to my trust item, he even asked me did u get a warning etc LOL its kinda lucky, note to self avoid all major roads.... except the m5 after 11pm
Police officers are not there to defect people, they are there to enforce the law and work with the community, let's just say this coppa
did the right thing and probably had other important things to worry about.
Tell that to the cops who pull me over for no apparent reason to defect me because i drive a skyline.
They tend to do that if you drives an import, it might be a junior coppa, where he/she just came out the academy still a bit hot headed and follows everything by the book.
+ I don't know what cops are like in Melbourne, they might have different discretion regarding imports.
Cops are tops!
I have no problem with the police, they're just doing they're job, and I don't get hassled much...
It's the laws I have a problem with... Half of them are like they're written by a work experience kid...
Cops are tops!
Pretty much the smartest thing you've said the whole year :P
i find that if your nice they generally dont give u too hard a time... maybe ask them a quesiton bout there HWY car... I did and it got me out a defect :down:
Pretty much the smartest thing you've said the whole year :D
+1 It was really smart.
Yeah, pretty funny coming from my mouth, 2 days after being defected huh :bunny:
But yeah, I can be pretty clever when I'm sober :down:
my bro is a cop and i asked him this same question the other day
the deffects stay on the system for up to 2 months i think he said and they will only remain on the system if they are real serious defects
Ahhh... good to know :down:
If it's alright with your brother, I may have some other questions for him too later on, I'm having trouble finding actual wording of certain laws...
What area of law enforcement does he work in?
he's a constable and he also does work in sumthing called a tag team or sum crap like that
haha yeh its all good, just hit me up with wot ever you wana know n ill see wot i can do for you, im constantly asking him about these types of questions
I just don't understand why people keep complaining about getting pulled over for nothing.
I've had over 15 cars with 90% of them turbos.
3 of them skylines.
a 200sx.
2 Liberty RS Turbo's with exhaust louder than most skylines can ever muster up.
Never ONCE have I been pulled over for anything other than RBT.
NSW or QLD.
Never.
they don't do it for no reason.
depends on the night there having too. iv had cops that just give me a breath test and off they go but i also have had a cop that was pissed off and was being rude to me from the get go. i was nice and polite and got red stickered my for a set of 18s and nothing else.
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
    • I was chatting with an ex SAU person who is involved in chooning euros now. He was saying the factory cars like Audi VW etc have something like 2000 tables that the ECU uses for getting everything "just right". Compare that back to any aftermarket ECU, and you'd be hard pressed to surpass 50 lookup tables. Even the Ford Barra engine has a few hundred lookup tables to run it (and they're still working some tables out too!)
    • Grab a temp probe, and probe each exhaust inlet runner with it sitting idling. Each one should be pretty darn close to the same temp. If you've got some reading higher or lower than the others, it's likely either air flow isn't equal, or your injectors aren't equal to each other.   The other things to check, is from the wiring changes that were made, were any earth's or grounds moved/changed.   Lastly, for the strut brace issue. It's not perfect, but can you get away with slipping a washer or two under the strut brace to raise it, and it still clean the bonnet? If you can, work out the height you need, that the motor can't torque up into, and get a spacer made for each side.
