Hi all
i noticed something strange with my 5th gear changes at Sandown a month or so ago, all gear shifts would be fine, but when it came to 5th, it would make this crunching sorta noise. It would still shift into gear, but it would make a 'not so nice' noise on the way through. I could be quite forceful/quick with the changes of the other gears, but really had to watch 5th and shift quite slowly.
I then saw this on youtube the other day
http://youtube.com/watch?v=aIMHbMXi178
997 911 GT2 vs Z06, driven by Chris Harris from Autocar (he does great reviews IMO) and the noise you hear from when he changes from 1st to 2nd at 5:02 (time of the vid) is the same noise i was getting from 4th to 5th at sandown when i was going down the straights.
Chris mentions that the noise is "beating the synchro's", what exactly is this and is it doing a lot of damage to the gearbox when it happens?
Gearbox currently has Redline MT-90 in it, but was thinking of switching to Redline Lightweight Shockproof, would this make a difference?
Was also thinking of get a C's short-shifter, but would this just make the problem worse?
cheers,
daniel
https://www.sau.com.au/forums/topic/218083-beating-the-synchros-5th-gear/
Mine does that up into 5 and back into 4.I put it down to the syncros.No idea how to get rid of it.Changed oil 3 times.
A friend of mine bought a new box from JJ and that did it in a gear aswell.Cant remember which.I think its the nature of the beast.
If you change hard and fast from a high rpm the syncros cant catch up and thats where you get the crunch sound.
Id like to have a go against the GT2 though,see how close we are :P
I get it from 3rd to 4th and I have a C's short shifter too. I reckon its just a problem of being over-enthusiastic on my part. In the end a standard gearbox taking 350rwkw fairly reliably is still a feat in itself, so I just have to remember that the time I could save by shifting like its the end of the world is probably in the tenths of a second per lap. I dont know if this is common, but I assume it is, especially mine being a 19 year old box.
Its just a problem with the synchros not having enough time to basically synchronise itself with the next gear, leading to the crunching noise.
Edited by Yawn
I get that sound shifting into 4th and i thought it was that my synchro is rooted. It still changes perfectly but just makes a noise. If i change properly without a clutch it doesn't make any bad noise and i can shift it in quickly.
Hi all
cheers,
daniel
i have exactly the same thing happen to me to....at high speed going from 4th to 5th get a crunch noise
mine is complete stock bar pod and exhaust, had gear box oil changed too, anybody now for sure what is happening here?
to get back to the start. for a given speed on the road, every gear has a different number of revs. so when you change gears you must get the engine to the right revs.
the synchros are soft brass rings that help get the gear spinning at the right revs, but being soft they do wear over time. Any time you try and put it in gear at the wrong revs the synchros are being worn. If you get the revs exactly right it will slip straight in.
synchros take time to work, the more difference in revs the more time it needs. You normally notice this with a quick up change in gears.
4th and 5th crunch most in these boxes because they have less synchro rings than 1-3.
So....if they are crunching they are worn and need to be replaced. In the meantime try redline oil in a worn gearbox it helps reduce the crunching or changing gear more slowly. But the only real solution is tear down the box and put new synchros in
Or if you don't want to do that just drive the car properly and change at the right revs.
You know he's talking about the track right?
And what do you mean change at the right revs?
I'm sure he doesn't have an issue changing at 4000 RPM, but its a track... :w00t:
Never get it and i bascially had water for oil in the diff.. Dont know what your on about and ive double clutched 4-5th heaps of times.. a few times i poped a flat change
R34GTT box isnt as old as in most cases stated here R32 GTR ones
mine did that from 3rd to 4th and changed to redline shockproof and that helped.
I'm sure he doesn't have an issue changing at 4000 RPM, but its a track... :P
I would have thought that if you don't use the clutch and change at the right revs(track or street) it wouldn't make that crunch sound because it's going straight in.
when i had no clutch for a couple weeks my box never made that sound getting into 4th because i would have to change when the revs were matched and hence no grind or crunch.
not sure exactly most cars but this is how you can find out. whatever speed your doing look at the revs. then change to the next gear normally(with clutch so you can see0 and see the revs. next time you change from that speed to the next gear let the revs go down to what the next gear was at and whack it in.
Took me a couple days to get used to using all 5 gears without clutch.
for example i drive first gear to 3k and the get out of gear an put it in when it's at 2k if i remember correctly.
wow, big response, ok
as Gareth said, it was track related, not road related.
It was happening when i was going down the straights, shifting from 4th to 5th at say... 140'ish?? not sure exactly. That's the ONLY time i've ever noticed it happen in my car, at high speeds like that.
so...
1) The noise is indicating the synchro's are being damaged each times it happens?
2) Yes, how exactly do i "rev match"
3) Should i perhaps give Redline Lightweight Shockproof a go?
4) Would a short shifter exacerbate the problem?
Should i just shift slower and more carefully went at the track, moving into 5th?
cheers and thanks for all the replies guys
daniel
working backwards
no it will make it worse
absolutely
when changing up - the only thing you can do is change more slowly. when changing down you blip the throttle to help "heel/toeing"
yes. buts its too late now so dont worry about that
seriously, all you have to do is put in redline and shift slightly slower. the only real fix is rebuilding the gearbox
guys start sim ple and go fro there....
check for oil leeks.... seriously... if you start to get crap loads of heat and 4th starts aswell and 4tgh only gets worse...bingo.....
only at high revs..... for 5th.... lacking oil or syncros....
oil is cheaper and gets worse quicker...but not overly quick...depending on leek.
    • I'm at the point of seriously starting a project to build and Arduino/mc (of some sort) based multigauge to go in the console where triple gauges normally sit. I have found a screen of the right dimensions. I would need to 3D print a bezel/housing to make it mount up pretty. That's doable. I would need to come up with interfacing circuitry for the EGT thermocouple. I'm sure there will be examples of that into Arduino out there somewhere. Ditto with characterising the output of the existing boost gauge's MAP sensor and the oil T gauge's thermistor. And then, because it is a screen, it can be controllable, so it can show more than the 3 gauges I currently have. So I can come up with a list of other things I want to be able to show on it that can be reasonably easily handled via an Arduino's inputs. I do not need this project. But the stepper gauges I'm using are giving me grief. It's time to come kicking and screaming into the 21st century.
    • Would you really prefer pillar gauges over something like this? https://www.haltech.com/product/ht-067010-haltech-ic-7-digital-dash-kit/ Or if you can spend more, this? https://www.haltech.com/product/ht-068000-haltech-uc-10/ I could write a thesis about how much better a modern dash is compared to a series of gauges.
    • People think it's a waste of space, ugly, etc, generally associate "emissions control equipment" with "bad". These OBD1 vacuum-only systems I'm not a huge fan because I think they don't go far enough. They're wasting some of the fuel captured because they start purging as soon as the engine pulls vacuum. Later OBD1/OBD2 they put an electric purge valve on them to vent only when closed loop is active so the ECU will trim some fuel out. Even later OBD2 with zero evaporative loss the tank is 100% sealed from atmosphere until you run the engine or press the refuel door release. The tank has to take much higher vacuum/pressure spec but you never deal with saturating the charcoal canister and losing some fuel that way. The fuel also lasts as long as it would in a 100% airtight container which is nice when you're dealing with modern E10 pump gas.
    • If your luck is anything like mine, what happens is in the process of pulling hoses to get access to the one leak you create many more leaks because every o-ring was on the verge of failing and the strain of pulling it apart caused it to fail. Sometimes life is simple, sometimes you pay twice trying to save once. For the R33 you can still get most AC components from Nissan, I use nissan epc data or amayama to look up the part numbers and then search for the cheapest/most practical way of sourcing from there.
    • The dirty secret is there is nothing recyclable about the plastic bag or old plastic bottles either. Our local trash collection explicitly calls it out as hazmat in both cases. Oil-soaked rags + paper towels too. Oil-soaked cardboard is also not recyclable. The most common case of oil-soaked paper like that is pizza boxes, which are explicitly compost-only from the oil. To my knowledge hazmat oil contaminated plastic the only solution is either landfill or "thermal recycling". Most plastics in my experience there is slow permeation of the oil it's holding into the container so it's very challenging to get it 100% clean.
