Hi.
I just checked my cam timing (RB25DET), the markings on the timing belt pulley on the crank, and the markings on the cam pulleys are all lined up. But when i checked the ignition markings on the crank pulley, it shows 15 degrees when the cams are ligned up with their markings. According to the manual, the ignition markings should be at TDC O degrees when the cams are aligned.
Has anyone ever checked their ignition markings against the cam markings?
How can it be possible to get 15 degrees offset on the ignition markings when all the timing belt marks are aligned?
OK the cam and ignition timing are not directly related.
You set the cam timing by lining up the marks ont he cam gears with the marks on the backing plate (correct as your pic shows) and the crank gear (under the harmonic balancer) with the mark on the oil pump. I can't see that in your pic.
The ignition timing is controlled by the CAS and is checked using a timing light when the motor is running. that is when you need to be looking for 15o (or 20o GTR)
Have you or someone else taken the timing belt off? Or are you just checking it? You can't confirm the cam timing is correct without taking off the harmonic balancer
Hi,
I've built the engine myself, so i know the position of the markings behind the harmonic balancer. I think though that there might be 1 tooth offset on the crank, I removed spark plug 1. and used a pin do check the position of piston 1. against the timing marks. the piston was not at top before I had turned the crank so that it alligned with the timing TDC. Also the manual says that the timing markings and cam markings should be spot on. I will move the timing belt one tooth tomorrow and see how the engine reacts then.
Thanks for your reply
Hey dude
I know this is going to suck but It looks like your timing is out. ( *edit* your confusing the cam timing to the ignition timing, your cam timing seems to be out)
When the top 2 are set on the marks the harmonic balancer should be on the first or second line. I cant remember for sure but i am pretty sure yours is out unless something is up with the balancer or something. I remember mine being on the first line which is 5deg on your manual you posted.
What your going to need to do is pull the harmonic balancer off and look at the COG...
I stole this from GTAAHH's post of his bottom cog. (and edited it for you)
You need to make sure the dot is on the mark on the oil pump. Look at pic here (open it)
Edit 2 (made pic more visable)
I have the front of my engine pulled appart at the moment because of a massive F OFF oil leak from what i think is the front seal. going to put it back together this weekend.
If you cannot see the . on the cog, then you have it on the wrong way (the dot is facing the oil pump not harmonic balancer as it should be.
It sucks cos you gotta pull out the radiator and the bottom cover and you MUST use a proper harmonic balancer puller, IF you use the one with the arms that grab on the outside of the balancer where the belts run THEN YOU WILL DESTROY your balancer. You must use the type that uses the M6 (or 5 cant remember now) bolts that screw into the balancer and you pull from there.
You have been warned... I will pm you my phone number if you have any questions when doin this mission.
Good luck
Edited by Guilt-Toy
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
