they failed me for the restraints fouling on the speakers, didnt say anything about how they were also behind the speaker. i just pulled the speakers out and they passed it.
i just sat there with a razor blade and eucolyptus oil removing the tint, wasnt hard, be careful if you do that on hte rear window not to scrape the de-mist lines
https://www.sau.com.au/forums/topic/218105-removing-tint/#findComment-3848603
Out of curiosity R3sp3ct, what was your tint % at Dickson, and what tint % did you pay for? Interested to see if it was the same..
My tint is 20% apparently and it came with the car when i got it a few months ago. I really dont want to remove it.
https://www.sau.com.au/forums/topic/218105-removing-tint/#findComment-3855989
No worries. I was quite curious because I paid to get my tint done and done legally (35%), yet when Dickson measured the windows, both fronts were 31% (the rest were all 35% exactly). The guy stared at me for a while and walked off and if they didn't get me for 4mm to low, i reckon he would have complained about my tint as well...
https://www.sau.com.au/forums/topic/218105-removing-tint/#findComment-3858867
They failed me on noise. Because they new they could get me on it they didnt go over the rest of the car...
Has coil overs, and much more they could of failed me for. They didnt want to pass it when i took it back with a standard system on it. But they had to.
Its good to have something easy for them to fail you on
https://www.sau.com.au/forums/topic/218105-removing-tint/#findComment-3860841
Anyone know what I should do about the child restraint brackets? They are mounted in the middle of the speaker but apparently should be in front of them??
Thats an odd one as both times I have been through the pits and they looked at the child restraints, mine are smack bang in the middle of the speakers as well.... There isn't much room to put them in front of the speakers is there? If we have a local place in the ACT that sorts out imports for compliance they may be able to assist, as they would surely have to do it all the time...
https://www.sau.com.au/forums/topic/218105-removing-tint/#findComment-3880440
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
