Damn the Subaru is ugly! Has anyone else noticed Subaru's move to building the ugliest cars on the road?
Take the new WRX and their SUV for example.. poo!
subaru have always made dog ugly cars... look at the subaru vortex *goes away to throw up*
but i do like some of the cars they make... the 2002ish model gt liberty's were pretty noice looking!
f*kui Tells Honda R&D: NSX Must be Faster Around the Nurburgring Than the GT-R
NÜRBURG, Germany — The latest prototype of the 2011 Acura NSX has hit the Nürburgring, and according to our sources in Japan, it has a very specific goal. We're told that Takeo f*kui, CEO of Honda, has tasked his R&D team with building an NSX that's faster around the Nürburgring than both the Nissan GT-R and the upcoming Lexus LF-A.
It's a tall order, and one that Honda hopes it can achieve through the use of a 5.5-liter V10 expected to make 550 horses, with a torque peak expected to top 420 pound-feet. The engine is essentially a slightly larger version of the V8 that Honda will use for the next-generation, rear-wheel-drive RL sedan, and it will use cylinder deactivation under light loads for maximum efficiency. Additional gains will come from the use of an eight-speed, paddle-shifted automatic.
Getting the power to the ground will be a modified version of Honda's Super-Handling All-Wheel-Drive (SH-AWD) system. Packaging could be tight, however, as this NSX will place its V10 up front. A combination of steel and aluminum will be used for the chassis that will form the basis of this 2+2 sports car.
What this means to you: The Acura NSX is less than two years away, and it's aiming to reclaim its title as Japan's ultimate supercar. — Ed Hellwig, Lead Senior Editor
Run.. Nissan/Lexus run..
(lol @ foul language filter)
http://www.edmunds.com/insideline/do/News/articleId=127306
Edited by ev0luti0nzer0
That supra has got to be the ugliest concept from toyota yet!
Oh and as a side note - probably old news to you guys in the know, but I read the new Porche 911 has run a 7:50 at the 'ring - Makes the new GTR even more impressive :thumbsup:
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
    • lol no cats running str pipes … might put the high flow back on but I suspect it might effect my ignition timing a bit.
