  • Replies 108
Nice idea for a thread! there are plenty of r30 pics on www.r30map.com if anyone doesnt allready know.
with the 3rd to last "84' Newman Skyline RS-X" can someone explain????? I thought only the HR's came in a Newman version.
some pics of my dr30
soon after buying it with my gts2 wheels
now got performance wheels, guna b painted black...
the other day after mounting new cooler/fan setup and iron mask headlights. will be off road for a while undergoing full upgrades
jon.
I see them bastards at r30.co have 5 stud hubs for the rear now :domokun:
Oh and c/fibre everything!! mmmmmmmmmmmmmmmmmmmmmm how to spend $$$ :stupid:
clean as dr mate.
u gonna use them panels with ur ironmask bumper? or keepin that bumper? cos i have same front and lights were abit off from the panel. also when ya put the bumper on it covers the side indicator, so either have 2 move it up the panel or just not use it. just lookin for panels my self.
lookin very tough tho man!
  Boof said:
I see them bastards at r30.co have 5 stud hubs for the rear now :blush:
Oh and c/fibre everything!! mmmmmmmmmmmmmmmmmmmmmm how to spend $$ :blink:
The c/fibre stuff is soooooooo sexy :ninja:
I want a 260kph speedo from there aswell
Any news on your DR shane, on the road yet? My mate reckons he saw one up past Salisbury way that looked like mine
  benny_blanco said:
The c/fibre stuff is soooooooo sexy :P
Nah wasn't mine mate, mines still sitting at home waiting for the brakes to be bled, fans to be figured out why they arnt working...And a pergola to be put up and yada yada....House FTW!!
Hey guys, this is my HR30 coupe fitted with a RB20DET, nearly finished. (the red one)
Should be completed and registered this week. (Hopefully)
Then all I've got left to do is put S13 coilovers with R32 M spec brakes, upgrade the turbo (don't know what with yet), retune the ECU and should be a nice little beast.
By the way how are you dennis? I quit my job and forgot to get your number out of the phone and have since lost my personal phone!!!
The silver one, well I think it looks f@#%ing HARDCORE!!!, Would love to get some of those over fenders on mine.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
