  • Replies 108
:cheers: That one is autographed by glen seaton :santa: Can't really see it in that pic but it's there, just infront of the 15
Both bought off ebay I presume?????
These posters were sold on ebay a little while back, as I was watching them till the dollars went through the roof.
I have both the GTR's and prints of them signed/autographed by the drivers along with the dunnydoor Jason Bright drove for HSV which is no longer procureable.
They are safely packed away for my kids, when they are a bit more valueable.
Cheers, D
hey everyone, my name is callum im from chch new zealand, my first car was a white four door r30 pictured earlier in the thread, i swapped this for george bryants banged up coupe. it had a f**ked diff which he claimed was an lsd. turned out it wasnt. the car was falling to peices, looks awesome in that pic in this thread though. i had it for anout 2.5 years, i did a manual conversion and tried to tidy it up a bit. i ended up selling it to guy here in chch who let its rego lapse. i am now building an 82 dr30 rs coupe with a turbo engine fitted, very excited...im sure it will go better then the l20et! anyways i saw this thread and decided to sign up
    • Atmospheric vent requires something that doesn't use a MAF for load. You would need a standalone ECU for that.
    • Hey all,   I’ve got an RB25 with a trigger kit that includes a crank wheel, and I’ve hit a wall trying to sort a timing belt tracking issue. The belt either rides right on the edge of the cam/crank pulleys or walks slightly forward once the engine starts. It tracks okay-ish for a moment, then creeps right to the edge—and honestly, it’s stressing me out.   I’ve spent hours removing and reinstalling the belt, double-checking everything:   Tensioner setup is good, checked multiple times Idler pulley and washers are all in the correct places Followed the RB25 timing procedure step-by-step     The only thing I changed was the rear crank washer—I swapped the OEM one for a Neato version, and it made things worse. The belt now sits even more forward than before. I’m beginning to think the crank trigger wheel itself (from the trigger kit) is the issue—poor design or slightly off dimensions.   What’s strange is that with the previous belt setup, it actually ran fine for a couple of years—around 4,000 to 5,000 miles, even with hard driving and high RPMs. But even then, the belt was always riding right on the edge, and I know that’s not ideal or safe long term.   At this point, I’m debating whether to:   Machine a few mm off the crank trigger wheel to bring it back in line, or Replace it entirely with a better-designed unit     Only thing is, I already have the Cherry Hall sensors, bracket, etc.—I just want to replace the wheel only, not the entire kit. Anyone know a brand or supplier that sells just the crank trigger wheel on its own?   Would really appreciate any feedback—especially from anyone who’s run into this exact issue and found a reliable fix.   Thanks in advance.
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
