  • Replies 108
:cheers: That one is autographed by glen seaton :santa: Can't really see it in that pic but it's there, just infront of the 15
Both bought off ebay I presume?????
These posters were sold on ebay a little while back, as I was watching them till the dollars went through the roof.
I have both the GTR's and prints of them signed/autographed by the drivers along with the dunnydoor Jason Bright drove for HSV which is no longer procureable.
They are safely packed away for my kids, when they are a bit more valueable.
Cheers, D
hey everyone, my name is callum im from chch new zealand, my first car was a white four door r30 pictured earlier in the thread, i swapped this for george bryants banged up coupe. it had a f**ked diff which he claimed was an lsd. turned out it wasnt. the car was falling to peices, looks awesome in that pic in this thread though. i had it for anout 2.5 years, i did a manual conversion and tried to tidy it up a bit. i ended up selling it to guy here in chch who let its rego lapse. i am now building an 82 dr30 rs coupe with a turbo engine fitted, very excited...im sure it will go better then the l20et! anyways i saw this thread and decided to sign up
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
