Head $SOLD
Short Motor $280 Perfect working order when removed
Coil packs (awesome Condition) with loom $100
Stock turbo Manifold $40
Stock cooler pipes $50
Aircon $120
Powersteering pump $120
R32 RB25DE NA Loom $100? Offers
R32 RB25DE NA Computer $100
R33 RB25DET Computer $140
Carbon Canister $20
Near New Genuine Nissan Water Pump $40
Brand new Genuine Nissan Timing belt $90
Cross over pipe $40
RB30 Sump $120 (basically same as RB25)
Probably got a few more parts I have forgotten will add later once I go have a search through
https://www.sau.com.au/forums/topic/218156-rb25det-parts/
is it a DET motor?
if so interested in the bottom end, as long as its not farked :blink:
not farked! Your welcome to come have a look!
did the rocker covers go with the head as well?
Sorry mate they did
https://www.sau.com.au/forums/topic/218156-rb25det-parts/#findComment-3873500
heya mate
drop me a Pm with a phone numebr.
pretty keen on that bottom end, and if i dont grab it, one of my mates might when we determine whethe his motors done a bottom end bearing,
cheers daniel
https://www.sau.com.au/forums/topic/218156-rb25det-parts/#findComment-3874545
heya mate
cheers daniel
PM Sent
Yeah could be keen on bottom end, we'll see how f**ked mine is when we tear it apart.
No worries
Hey mate, interested in the bottom end. Got any compression or leak down tests done before it was taken apart?
Sorry didnt get a chance :)
Hey Mate,
Was wondering if you still have the metal cooling pipe that comes from the turbo and follows up to the back of the engine.
It's a small thin metal pipe.
Cheers.
Gone - went with the turbs!
https://www.sau.com.au/forums/topic/218156-rb25det-parts/#findComment-3879537
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
