well seems no one else will do it i did. heres what you need to do to remove the reversing beep and the reversing beep only.
To start off with sick your head under the steering collum,the box you are looking for sits right up on top of the steering collum on the right hand side (above your right hand leg when your sitting in the car).
The box your looking for looks like this
In the picture above the white plug faces the firewall.
unplug the plug from the box and pull away some of the insulation tape,proceed to cut the RED wire only,this is the trigger wire for the reversing beep.tape the live end up and plug it back into the box and your all done.
Jack
https://www.sau.com.au/forums/topic/218162-how-to-remove-reversing-beep-in-r33/
yeh they have a beep for everything, lights left one, reversing and leaving your keys in the egnition
i have a manual 33, it has the beep for keys in the ignition while the door is open and headlights while door is open but not reverse.
taht will stop the beep when u leave ur lights on...im pretty sure...cos i wanted to do the same thing but was told that it gets rid of the lights beep
This will only remove the reversing beep.the lights on beep uses a different buzzer.
I never knew that was an option in the 33's....Never came across a 33 with it.
The reversing beep is only in the auto R33's
Jack
I can confirm that the reversing beep sound is a feature only in Auto R33's... I love it... it have syncronised it with my reversing camera - works great... I've bought a unit to auto turn off lamps after 5 minutes as well... like the Mercs... damn great...
Someone mentioned the beep that sounds when the door is open, with keys in the ignition................I (and I assume others) like to sit with the door open and legs out the door occasionly, listening to the radio. Is there a way to stop this particular beeping......MY GOD IT'S ANNOYING!!
yes there is my friend.ill add how to remove that beep to this tut soon.
Jack
  • 1 month later...
i always thought that the beep was put in, so u knew u were in reverse (( so if by accident u put it in reverse and floored it you wouldnt crash (if parked or something.
its the only logical thing i can think of
  • 4 weeks later...
  • 1 month later...
Hi Guys, just joined here and thought i would give my feed back.
I just bought a 33 on the weekend, its a manual and it beeps as im reversing, glad to hear that you can get rid of it. Its quite annoying :cool:
Unfortunately it sounds like your car has been converted to a manual (mine has been to), it got done at the dealer. I found out after i brought it, because of this reason my car over revs in 5th, because they didn't change the entire thing. I have asked a few mechanics that deal with skylines regularly, and they came up with these reasons.
That's right, its a warning that it is in reverse, not a warning for pedestrians etc behind the car.
It can be heard inside, but you can't really hear it outside the car
I think thats correct about the warning... even though how annoying it is
Yes u cant hear it outside, i get comments from passengers that my car is a truck, it is annoying as. i might try that wire cutting. Sounds like a plan. so thanks.
Edited by Timmy21
  • 3 months later...
Arrgh one of the more annoying features... a beep INSIDE the car for idiots that don't know they are in reverse...
There is actually a warning in the car's handbook (which I have a translated version of) that mentions this fact that it can only be heard inside the vehicle.. so funny, so useless.
Some of the other illustrations in the handbook are very amusing..
Stagea Handbook but applies to Skyline as well.
I will be clipping this wire methinks.. hope it's the same colour on Stagea.
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
    • I just try to entirely stay away from ladder now unless it's something basic maintained by electricians. Even then and to your point, it mostly ends up being blocks I wrote in structured text.  PLC's are slowly going towards C, C++ and C#. I just wish Allen-Bradley would jump on the bandwagon.
