  • Replies 895
Mine idles dead flat. Try spraying some carbi cleaner around the rubber seals of the injectors, if the revs change then it means you have an air leak.
These things use closed loop control of idle, but use the settings in the open-loop table as a rough starting point for idle control duty cycle, so you set up your idle in open loop and then switch on closed loop and it is done.
Havent taken it to ESP yet, will talk to them tomorrow, taking the car back to Skyline Performance to fix a slow oil leak first. Car also broke down on mild throttle when I took the car for a quick drive yesterday. Was breaking down on anything more than 4-5psi when esp were first tuning it. after the put in new bkr7e's it only did it once on the dyno.
Was advised by someone else putting in better sparkplugs wouldn't hurt?
use PFR7B's on pump
coils maybe.
Use BCPR7ES forget platinum plugs and tell your tuner to stop using BKR's in RB's.... they are 2.5mm shorter and only amplify ignition problems due to poor contact.
this has been my plug of choice for a couple of years now and i couldn't agree more...
have used for 185, 240 and 265 rwkw
I use it now too. Only problem is having to order them in prior to each change.
most repcos have them in stock, i usually buy 30-40 at a time of both BKR7E and 20-30odd BCPR7ES cause my work is split between RB's, SR's and JZ's.
*backs away from narre autobarn being veeeery careful not to take eyes off trent*
haha nah but they always have Z32's, BCPR and BKR plugs 040's, 02 sensors etc out the back ready to go for me so if anyone ever needs them in a hurry on a sunday or whatever it may help you out. Crazy range of silicon hose instock too.
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
