Nope , doubt that very much .
No way manifold pressure sensing can achieve what mass flow sensing can , I guess people can't get their head around the fact that the appropriate MAF sensor is not restrictive .
I had been just about to ask if the new box supports larger than std MAF sensors like PFC's do but no point is there .
Lost me , cheers A .
Power FC Djetro cars dont run as well as AFM models...is that what your saying?? AFM reversion, stalling/overfuelling, etc...not a problem with AFM equipped cars??
To each their own i suppose...
Boost control...yes
Edited by DiRTgarage
  • Replies 895
come on man your killing us (and i bet your enjoying it slightly)
out with it... :)
ill have a further discussion with the manufacturer tomm. and see if i can leak a bit more info pre-release
but yes...im loving it :D
any questions you would like me to ask please feel free to list them...OK
a price range would be nice
unless you're going to try and milk the market
as you may or may not appreciate...this is not my product. As a potential distributor i intend not to jepardise my relationship with the manufacturer by quoting prices or other information without their consent. All i can say at the moment is it will be dearer than a new Power FC and cheaper than a MoTeC.
Im just providing a little 'heads up' pre-release so you have a bit of background on it.
sounds interesting cant w8 2 c wat it will be like. another q is with the tuning will it come with a cd with the software 2 install on laptops 2 tune it or will this have 2 b purchased seperatly. and with the boost controll can it still run with other boost controllers like the greddy profec 2
boost control function is able to be done separately to the ecu.
software supplied and updates available on line through internet/email
How long away is this thing from being launched?
will get a date for you tomm.
we are going to run one of these in our 9 sec drag car to see how they handle a high power race application. The flat shift function will be interesting to use as well as the two-step launch limiter.
wow you obviously have alot of confidence in the product " or alot of spare cash" just incase its not what its cracked up to be.. lol
on a side note, so happy its a map sensor based system, airflow meter's suck..
Is it a megasquirt with some electronics to suit skylines attached?
Thats how I planned on adding all the features you mentioned to my car using as little money and R&D time as possible, I got majority of the way there too. Open source that bad boy and make all your money on hardware & tuning, people will join you in making it truly competitive to motec and autronic.
ZOMG full hektic sik bro!
wifout da afm i can run da siiiiiiiiiiiik dose!
seriously tho.... pfc's are the fav because of tuning availability..
does it run the climate control and other shit?
also interested, depending on price mainly...
I feel like I know you a bit Paul, and you wouldn't put your name anywhere near some POS item :)
I'll be needing an ECU fairly soonish, so lemme know if you need to test a street application :thumbsup:
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
