  • Replies 895
or because link do the manufacturing for them and already had that casing designed it was cheaper to just use it than design a new one?
Seperate companies manufacture the cases as well as the chipsets...they supply their products to both Vi-pec and Link...this cuts down on design and manufacturing costs for both Link and Vi-pec. A sensible arrangement really as it makes the end product cheaper for the consumer.
Edited by DiRTgarage
When I took the end plate off my Vi-PEC V88, the PCB is screened with G4 Extreme. I love my V88, will be grabbing a V44 shortly for my other car and I'll bet if I tried to update it with the Link G4 storm firmware it would have a good chance of working. On Link's website you can also associate Vipec ECU's with your user account there too.
so the question has come up, are they the same. I just downloaded both software from both sites and they are identical.
We were told software was different.
Also checked the price tag, seems as if the vipec is around $400 more expensive. What would be the reason for this if they are the same? they are looking like the same product so far.
what i can make of it, seems as if the links use a adaptor harness for the plug ins where the vipec has the nissan plug on the board itself.
Is that what we are paying the extra $400 ? a true plug equiv of the link? that was developed by TFelectronics?
go through the vipec software help files, look at the screenshots and the titles used in each. All are PClink.
The suppport from Ray for the Vipec in my experience is very good, I rate that highly on my "needs" list. Similar queries that went to Link in NZ weren't as quick. I'm happy to pay the extra for the local and fast support.
this may be the case, the extra $400 may be worth TFelectronics known good support + the direct true plug version. Seems like they are trying to hide something that may be a good thing??
okay, looks as if the difference i can see is that the TFelectronics version is a modified version which makes it a true plug in.
Here are pics, as you can see the Vipec has a Nissan plug on the board and this would mean the board would have to be totally re-designed to do this.
This one is the TF Electronics board...
And this one is the link adaptor
So basically, TF are doing the same with the Link as what he was doing with the Autronic plug in's.. taking a ECU and engineering it to work directly with the OEM wiring harness - take the guts out of your ecu and put this one inside it and you have a true plug in.
So yes the nissan plug in's would be a different ecu, with the same software and chip. But the other wire in jobs, like the V88 ?? Who knows.
For me, the V44 plug in. I am going to bite the bullet and say that the extra price might be worth what your getting, But stay tuned.. we will see how it goes when i get my ecu soon! Then I will make judgement for sure.
You gonna take the V44 to Yavuz for a look-see? I reckon he'd like a look at it.
yeah i will give him a call once its all going, i think he is more interested in the Gizzmo K-Mon though
from my experience, the support and customer service for me has been fantastic. Lincoln has been more than happy to answer any questions i have had and help out with any issues i have encountered. I couldn't recommend him enough to anyone looking at purchasing one in NSW.
yeah, shifting:
Original reply: nope, you are imagining things, they are different
New reply: ok, some parts come from the same vendors
Reality: they are the same except for the sticker on the case.
From the horses mouth...Ray Hall...hope this puts an end to the speculation that the Vi-PEC is a rebadged Link...its actually the other way.
The Vipec was developed to my specification and uses a lot of the features associated with the Autronic ECU. I wanted a ECU that was better then the Autronic in areas that had caused me and my dealers a lot of frustration when tuning. The Vipec works just as I requested, and as can be seen from this forum and other feedback the product is very good. If I had stayed with Autronic, and had not influenced the design of the Vipec, the Link product would not be close to the way it is now, which is a re-badged Vipec.
The Vipec comes with mine and the Vipec dealers support. If you want that support, then you have to pay for it.
Ray.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
