  • Replies 895
Hmm, strange, ..... well at least your seeing the same results, so thats re-assuring for me, thanks for the feedback.
God i LOVE the interpolate, and "copyright" haha Simple little things that just make life SOOO much easier.
Oh yeah.... i called past the dyno on way home and tried to pull a log.... and his laptop did connect , however when trying to save a log, it saved nothing, and after a few tries it locked up and said firmware needs reloading or something... and i shit as i had to pick up stepdaughter in 10 mins. But a power off sorted it ..... i did have 4.2.1 however so i did upgrade to 4.3.4. So got me stuffed why my lappy doesnt work in datalog or update... only pclink.. weird. will try it again tomorrow with new firmware inplace.
Gary
Gary
are you trying to run an old tune on previous firmware? I believe if you update the firmware you must open a new tune file and copy and paste the numbers over. It should then log ok then.
No dirt, All new from scratch, last old map is outta GTST link, and not even the map numbers are remotely compatabile.
err rather embarrisingly, i didn't have the ecu logging turned on.... hence why no data. i assumed it was on. Silly me !
I kept looking at the software throughout the day thinking..... where the hell is the ecu logging .... i know i'd seen it once.... And of course it didn't show up until plugged in this afternoon on way home! Doh.
My laptop still won't pull a log , says it can't connect still, but im about to go out and try it now, as i just updated to .NET 3.5 .... hope that is the prob.
Gary
Edited by Fastrotor
I finally got to pull a log down, however the .NET thing didnt do it .. I had to go into the com port driver settings and turn off the FIFO enable. However firmware update still cant see ecu.
Dirt, i did this map in ecu firmware 4.2.1, using 4.3.4 pclink. Ecu is now flashed to 4.3.4 (using mates laptop). Do you think this might cause dramas ?
Gary
Replaced my IAT sensor, IAT Temp behaved all of last night, car idled better, still not 100% as it was before the turbo went. But no huge hunting problems. Did break down once slightly. May have knocked the main issue on the head though.
Guys,
I was just out playing with comp, pulling logs etc ... and i noticed 2 problems... When i log on the PC inside PCLink, no problems at all with all values displayed.
However, when i use ECU logging and then play back one of the downloaded logs, the Wastegate DC reads whatever value the solenoid is last at when you logoff PCLink to run the playback. Normally this is 0, but i lowered all the lockout values etc to get it showing a value at idle, just to verify, and sure enought that constant value is in the ECU logs.
Also, i use Analogue 4 as a GP Pressure (link 2.5Bar) using CAL5 . Logs fine in pclink logging, 100kpa with engine stopped, as it should..... but ecu logging shows a value of 10 ...
Anyone had issues with discrepancies between the two logging methods ?? Im heading over to the link forum now to post these issues. Just thought id mention it here for general info incase you come across it.
Gary
first pics of the engine monitor...will update with more info after full installation and testing is complete.
The unit plugs straight into the CAN bus port and is fed data direct from the Vi-PEC.
my photography skills are a little bit poor.
Here in Adelaide I've been quoted.
Vipec V88 - $2475
Vipec R32 Plugin - $1765
External knock amp to suit the plugin - $235
I've seen them around cheaper (boostcruising I think?) so now to find that link again. :)
1) $1980+tax+frieght
2) $1350+tax+frieght
3) not on my current pricelist.
dirt have you seen the LInk display unit? plugs into usb / can connector. $800+tax
The DisplayLink is compatable with all Link ECU's that can run PCLink
Point of Difference
The DisplayLink is not a preset segmented LCD like other aftermarket "dashs" but rather a full graphical display that is clearly visable even in direct sunlight.
Features
Full graphical gauges for every measured output
Crystal clear 320x240 display viewable in direct sunlight
User selectable contrast
Intuitive user interface
CAN bus for future expandability
Waterproof aluminium enclosure
Logging
Up to 20Hz data rate from ECU’s
Supports LEM, LinkPlus, LinkPlusG2 and most Plug-In Link ECU's
Onboard FLASH memory for continuous logging
Up to 30 minute data logging
Playback on dash for after event analysis
Graphing
Multiple axis graphing available on screen
Graph can be paused or cleared and used to display playback of logged data
All data available can be graphed against time or any other parameter for onboard analysis
Graph MAP against RPM to aid boost control setup
Alarms
Alarms can be set to warn user of dangerous conditions (eg over voltage, low oil pressure)
Combinational alarms can be set (eg. AFR is greater than 14.0 AND MAP is greater than 150kPa)
Alarm is displayed on screen and warning LED flashes
Gauges
Multiple styles of gauges for user preference
Some gauges have “peak” memory showing previous peak value for 2 seconds
Digital gauges display up to 8 different runtime values on screen for diagnosing problems
Digital gauges may be customised to user preferences
Customisation
Four fully customisable run-time screens available
Group information in whatever order is most useful to you
See the list of parameters available below
Sample Screen Shots
http://www.linkecu.com/products/TuningTools/DisplayLink
Available parameters *
RPM Engine Speed in RPM
MAP Manifold Absolute Pressure in kPa
MGP Manifold Gauge Pressure in kPa
BARO Barometric Pressure in kPa
TPS Throttle Position
INJ DC Injector Duty Cycle in %
INJS DC Secondary Injector Duty Cycle in %
INJ PW Injector Pulse Width
ECT Engine Coolant Temperature in deg C
IAT Intake Air Temperature in deg C
ECU_V ECU Voltage in Volts
WB02 1 Wideband O2 (AN 1) in AFR (Air-Fuel Ratio)
WB02 2 Wideband O2 (AN 2) in AFR (Air-Fuel Ratio)
GEAR Selected Gear
FUEL T Fuel Temperature in deg C
INJ TM Injector Timing in degrees BTDC firing
IGN Ignition Angle in degrees
I CAM 1 Inlet Cam Position 1 in degrees BTDC
I CAM 2 Inlet Cam Position 2 in degrees BTDC
E CAM 1 Exhaust Cam Position 1 in degrees BTDC
E CAM 2 Exhaust Cam Position 2 in degrees BTDC
KNK 1 Knock Level
MAF Mass Air Flow in g/s
AFM MAF meter signal voltage
TEMP 1 to 4 GP Temperatures 1 to 4
PRESS 1 to 6 GP Pressures 1 to 6
SPD 1 to 6 Digital speed inputs 1 to 6
ON BD T On Board Temperature in deg C
* Depending on ECU model, and installation configuration
Dimensions of Body
25 mm depth
137 mm width
91 mm hight
Edited by URAS
Well ive decided that im going to sell my PFC pro in the coming weeks, and get one of these as im about to go a big power hike it will be cheaper for me to sell the PFC pro and buy one of these and save myself some cash by not buying a Z32 afm. :D
I'm looking at getting a Power FC for my 34 gtr, thought I would revisit this thread.
I have to say all these little dramas are not convincing me to get a Vi-pec.
I'll admit I havent read EVERY page, just the first few and the last 4. I'm also not the most technically minded, I just like my cars to run fast and reliably. I'm not a tamperer, I dont adjust what my tuner does.
Does the Vi-pec suit my needs or should I stick with a PFC, of which I have never had a single drama with in the past?
Any help/advice Paul or Trent would be greatly appreciated.
What dramas ? There are no major dramas with the LINK/ViPEC . Little very minor stuff you would never notice as end user, but its always being updated with new features and things get fixxed.
But if your not that technically minded and don't want to play with it yourself, why not just go see your tuner and ask what he would like to use..... as in the end of the day, to you, the end result is what matters.
But i still say get one. From a tuners point of view i can say there bloddy brilliant. Ive used LINKS since the early ones and this is the first one i've got really excited about...and still am ! :D
Gary
On the topic of compatible dashes with the Vipec I have contacted Stack in the UK (I am sure many people are familiar with the Sard Stack dashes which are manufactured by Stack UK which supply Sard).
Anyway they have a dash that may be compatible with the Vipec ECU via CAN port, at the moment the AIM MXL, Motec ADL2, Racepak IQ3 and Race Technology DASH2 (soon) are compatible with the Vipec. Would be cool to have a Stack dash in there too, they look awesome with their analogue tacho and LCD display!
I have contacted Ray Hall too, if there is any serious interest I am sure the Stack MFD ST8916 could be added to the list.
http://www.stackltd.com/st8916.html
Mike
My Vi-PEC is by far superior product than anything ive used before...its top shelf.
but your tuner should be the one you are asking questions to as he will be the fella crunching the numbers into whatever ecu you choose.
I'll have a chat to Beno and see what he thinks.
Gary, you ask what problems lol, I was referring mainly to your posts. Try reading them again, you would scare the hell out of anyone thinking of buying one.
Its all good, I'll keep silent and just keep reading.
    • She swallowed the spider to catch the fly.
    • Half anticipating the next question then: I have two magnets stuck in my oil pan. What should I do?
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
