Hi, Paul Ruzic here. I designed and built the EM PRO II and RaceLogger. I will happily discuss the technical specs of the unit but cannot discuss pricing or availability as per forum rules.
The EM PRO II was originally designed as a stand alone unit, then dirtGarage made the introduction to Ray Hall and the ViPEC ECU. So now if you have a Vi-PEC you can plug it in and reallocate all the normal inputs the EM PRO II already has to other channels expanding its monitoring capability.
Technical Features:
6 analog input channels
Engine RPM input
Vehicls speed input
Remote data page push button
Remote alarm acknowledgement push button input
2 Stage shiftlight output
Warning light output
Alarm buzzer output
Auxillary output for a relay triggered by RPM or Speed or for PWM electric water pump speed control.
Serial data output for loggint with the RaceLogger
Serial data connection to the Vi-PEC ECU
The EM PRO II has 5 data used to show details of each individual data channels that are being monitored. Each of the pages can be configured to show up to four input channels at at time. An optional remote input button mounted within easy reach of the driver can be used to scroll between the pages.
Each monitored channel can have a "greater then" and a "less than" value assigned to them. The alarm situation can trigger the warning light / buzzer or both.
The proiority of the alarms can be set so the most important alarms are always at the top.
Up to three alarms can be seen on the screen at once.
The alarms can be set to hold for a minimum time so they are never missed or to not clear until acknowledged.
To ensure oil pressure is maintained through the rev range, the EM PRO II has two additional oil pressue points that are set referenced to RPM.
Without a Vi-PEC you can piggyback signals from the ECU (so far we have done units in cars running Motech, Haltech, Autronic, PowerFC) and also provide addtional sensors for signals ECU's don't usually support such as Oil Pressure, Oil Temp etc. With a Vi-PEC you can still add up to 6 additional channels using extra sensors.
Vi-PEC Channels Supported
RPM
Knock - also allows option to alarm knock against the Knock target table
MAP
MGP
Injectory Duty
Injector Duty (stg)
Coolant Temp
Air Temp
MAF gs
Knock Count
Temp 1
Temp 2
Temp 3
Temp 4
Volt 1
Volt 2
Volt 3
Volt 4
Volt 5
Volt 6
Volt 7
Volt 8
Volt 9
Volt 10
Volt 11
When connected to the Vi-PEC data logging is performed with the Vi-PEC ECU. When stand alone the EM PRO II can be connected to the RaceLogger to add to the logging capabilities of the RaceLogger.
The EM PRO II has external Shift lights / warning lights and a large alarm buzzer for optimim setup for racing. The external page select / alarm acknowledge buttons also allow for driver convienient mounting for racing.
I have to also thank guys like Paul, Darren, Duncan, Mick, Noel, Gervase, Simon, Danh, Cam, Mark, Mitch, Pierce and others (you know who you are) who have supported this product through development and testing.
Thats the quick overview of the unit. I almost have a brochure ready (thanks Cam) which will detail all the information.
Hi,
I've already purchased a vipec for my r34, so if i purchase one of these EM PRO's does it need an additional oil pressure sensor to get a oil pressure reading (ie it can't use the same one that the stock dash uses?) if not, will a signal from an aftermarket electronic oil pressure gauge such as an apexi etc work instead?
:banana:
  • Replies 895
The sensors used by the dash are not usually the best. You can tap into other sensors such as the Apexi as I allow the user to enter any calibration data they want. You just need the calibration data for that particular sensor. If you PM me the sensor details I can check if I already calibration data for it. Else you can get new sensors, which are not very expensive.
Thanks for the reply, i havent bought any gauges yet, thats probably one of the last things i'll get before the build. Any particular electronic gauge brands that you know will work with this dash? Just to keep things neat, if i could get away with running only the one aftermarket sensor that would be good.
It will work with any gauge, you just have to sniff the signal line. The problem is the calibration data.
With the Dash you don't really need gauges as well as all the info is shown on the Dash and if something goes out of range you get an alarm.
Having said that, if you really want a particular gauge I can calibrate the sensor if you send it to me and add the data to a public library for others.
Here is the brochure and specification sheets that Cam has done for the product (thanks Cam)
http://www.timeattack.com.au/about/about/em-pro-ii.html
http://www.timeattack.com.au/about/about/e...ifications.html
I'm looking into buying one. Can someone clear one thing for me.
1) Can I use the LINK dash with the plug-in board ? Or I have to get a V88?
2) If I go with V88, is there a plug and play adapter for the RBs ? r32 socket ? (they have one for supra)
3) Is it possible to use LINK G4 plug in adapters ? Or the pin out is different ? Haven't looked at that yet. Just and idea.
Thanks!
Anyone else had issues on cold start? twice now after not starting the car for 9 days or so, the idle was quite bad, car would not idle for 30'secs or so. Havent hooked the laptop up to the car when I've done this though. Car idles fine if I drive it every few days.
Just a note for those running an RB25DET or similar , where you get timing off the Primary loop at the ignitor.
I noticed i had to change the offset alot on the G4 to get the timing to the 0 mark when aligning ...... Guilttoy was the same it seems ......
And maps took a fair amount more timing on boost. tried several timing lights to confirm and seemed all good.
However tonight i timed it off the coil directly with a short custom lead i made up for testing coilpacks...... And low and behold it was close to 10 degrees retarded !!
So i retimed off the coil and then pulled same timing out of top end maps......
I guess it wont make a diff to top end power, but low end might if your used to running a certain timing and didnt up it ....
Anyway, for your info........... and for guilttoy to check !
Gary
How do you guys hook up the switch for the clutch and what did you use?
factory clutch switch with a 12v feed into it and then into a DI input on the ecu. don't remember which way it works clutch in for 12v or 0v but that's all changeable in the ecu
Call Mark Jacobsen at Godzilla before you make your decision. (07) 38904488
do you guys tune many HALTECH's? if so we are finalising some sweet tuning aids for it as the STD 2d tuning interface is pretty poor.
So they changed out the AEM for the Vipec now?
Gonzo was raving to me about how good the AEM was. Good testament to the Vipec if they run a faster time. Any ideas what times they've put down?
The stickers on that car will tell a thousand words, look carefully. Installed by a very capable tuner and his sidekick :)
That was a rhetorical question.
I saw the sticker on the tail, probably shouldn't have put the question mark, but my unforgiving need to be grammatically correct overrides my need to be easy to understand, if that makes sense.
I am aware of his skill, not sure why you pointed that out.
I was merely making a statement that an already impressive car used to run an AEM, now it runs the ViPEC. It will be a good testament to the ViPEC if that car can then do better times as a result.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
