But only has 4 ignition drivers unless you want to get a V88.
Hopefully haltech will release more plug and play models
I do not know how the ignition outputs work but there is a plugin model for both the R33 and R34 skyline.
  • Replies 895
the plugin model runs wasted spark (two coils fire at once) i have not had any issues with this setup as of yet.
Our street/circuit GTR runs a plug-in...over 600hp (24psi) at all four and pulls harder than a one armed 15 year old with a stack of porno's.
  • 1 month later...
Hi guys, I'm using a plug in VIPEC in my R32 GTR for 3 months now and since the install there's been an intermittent problem with my Atessa which brings up the code for TPS fault. I've read a post somewhere by someone saying that this problem had happened and was possibly caused by the ECU creating a voltage drop (also with an Autronic) and the correction was a voltage buffer or some sort. Could anyone get into detail about what the fix is? I'm getting tired of losing my AWD mid corner on a hard drive and having to turn the car off to reset the Atessa..... Please help.
I'm only running 302whp at the moment but building for 500whp this winter and I can't have the chances of intermittent traction loss. Thanks guys.
Check your TPS is correctly adjusted and tightened firmly...the plug-in boards have never had an ATESSA issue...only the V88 when running the early harness adaptor.
Thanks! I'll check it out. I didn't know it was only the V88. Was hoping it was any of them lol. Back to the head scratching...
Can anybody recommend a distributor that I can contact to purchase one of these ECU's from??
The distributor local to me is one that I wont go to for seperate reasons and being in TGassie makes it hard to shop around some.
I am looking for somebody who can supply an ECU with a base tune already in it so we only need to fine tune it to my car.
Would like to have this in a and running before christmas.
Speak to Brett West at Adelaide Performance Engineers (Graham West Workshops) see what he can do.
I was in Burnie a few months ago, nice little town!
Us southerners get shafted for dealer choice...
If Dirtman cant help, call godzilla motorsport.
  • 2 months later...
Curious to know what message do people get when they hook up their ecu to their laptop for the first time? Ie when it's asking to install the drivers? Vi-pec are sorting out an issue with my ecu, but curious to know what peoples ecu's come up as.
Mine says found new hardware "Link G4 Extreme"...lol
So sounds like it should recognise it as a link?
hmm mine wont connect to my laptop running vista (cant find the drivers, ive tried multiple reinstalls on the laptop), and comes up saying link electrosystems ECU, but getting a new top board from VIPEC so will see if that sorts out my issues. It connected fine with my old xp laptop, but will not work under vista. And will also will now not connect under my other laptop running xp.
CeJay...my last post was supposed to be funny...sorry you missed it. Have you checked the vi-pec forum for answers?
Yes I have, and hopefully it's getting sorted, getting a replacement top board from Ray, because my ecu doesn't come up as a vipec, it comes up as a link. Was genuinely interested to see what other peoples ecu's register as.
And here i was trying to be funny and i was on the money.
We tried reflashing a Link with the Vi-pec firmware to test the theory that the hardware was the same...it didn't work. We tried flashing it back and it wouldn't work back as a Link...we killed it! Link sent us another one to replace it.
Edited by Swiper the Fox
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
