Hi guys, because I'm a bit of a parts whore I have ended up with 2 sets of lowered springs for my V35. Tein S-Tech and Tanabe NF210. I thought it would be interesting to show the difference between them and how these two companys tackle the same task. Both sets sit at the same length when free but the manufactures quote different heights. They also have quite different spring rates.
Does anyone have any opinions or preference to either brand?
Tein (green) lower front 1.2" and rear .9" Spring rates front 6.4 and rear 4.9
Tanabe (red) lower front 1" and rear .6" Spring rates front 5.3 and rear 6
https://www.sau.com.au/forums/topic/218187-compare-lowered-springs/
Have you tried both of the bands on you car? Is one smoother / harder than each other? Which on handle better?
I have sat in a GTR with Tein coil overs on stock GTR suspension towers. It was in fact nice smooth ride with the cornering/handling capabilities better than the stock coil overs.
I got Cusco's and I get a damn hard ass ride! LOL!
in my opinon, why put springs that are only 1inch lower?
is it worth the hastle.
Personally if your going to the hastle of pulling your suspension apart and incresing the stiffness of your springs you would want the pay off of having your car riding alot lower. Changing the springs for harder ones that aren't really much lower would be a bit point less. (for me anyways)
Like Z33's, V35's and M35'S have different movement and leverage ratios front to rear. Particularly the rear where the springs are located inboard on the lower control arms, separate from the shocks which are mounted closer to the wheels. So you can't simply compare the front and rear spring rates. The effective (what the tyre and chassis feels) springs rate calculations are;
Tein (green) lower front 1.2" and rear .9" Spring rates front 6.4 (effective = 4 kg/mm) and rear 4.9 (2 kg/mm) Are you sure these aren't the wrong way around (front 4.9 and rear 6.4)?
Tanabe (red) lower front 1" and rear .6" Spring rates front 5.3 (effective 3.5 kg/mm) and rear 6 (2.5 kg/mm). That's much more sensible.
Based on the above I would prefer the Tanabes over the Teins. Not saying the Tanabes are any good, just that their springs rates are better than the Teins.
To avoid confusion with the R32/33/34 which have very different suspension layouts to the V35, I suggest you post further questions in the V35 specific section.
Cheers
Gary
  • 3 months later...
Sorry that I haven't seen this thread till now...
My son has an R33 GTR and installed the Tein springs. At speed, they are extremely good with rates suiting all kinds of undulations and mild bumps. At low speeds as a street car, the suspension then seems hard, jiggly & jittery.
My R34 GTR has had Tanabe springs installed. They're a progressive spring and they seem to take everyday roads with ease in conjunction with existing shocks and damping. There are no sudden bumps or jiggles with these. At speed, the car feels just as planted on the road as the R33 with Teins.
I know I have to take into account that these are two different cars w.r.t. slight oversteer on one Vs neutral on the other but...
Personally I prefer the Tanabes eh?
Thanks for the thread! :blink:
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
