Hey,
Just want to confirm I got the correct braided brake lines as they look completely different to whats on the car.
I've attached a pic of what the R32 GTR ones look like from the Markk group buy on ADR approved lines.
Is this the correct ones for an R33?
They don't look anything like whats on there now so I'm not sure about fitting them on....
Has anyone fitted there R33 GTR's ones?
Are these the correct lines?
Apologies for the terrible pictures, I don't want to take it out of the packaging if it is the wrong one....
Regards,
Gareth
Yeah, i received the incorrect ones, but it was no ones fault. Ive got a 93 r32 gtst M spec which should use the gtr ones pictured above, but it uses normal r32 ones which do not have the 'V' shape for the front lines. Ring Goran at Brakewest if you have any further problems. His customer service is excellent.
Shaun.
They are the right hoses mate.
PM sent with further details.
Cheers
Thanks a lot Mark.
I think my current ones must be aftermarket then, I have a 1 piece brake hose on the front with a bracket there to hold it, it doesn't look like these particular lines will be able to connect.
I might need some other parts to put these in.
Does anyone have a picture of what the factory R33 GTR lines look like?
I'll try and post pictures of what my ones look like tomorrow.
I created this thread to confirm that they are standard lines.
But still no idea how to fit them, does anyone have an install guide for the braided brake lines?
Or any tips on how you installed them? I can't see how they would connect the existing system doesn't have block connectors on it at all.
Thanks,
Gareth
if they are the correct lines you should just unbolt your old ones from the caliper on one end and from the hard metal line at the other end, then install the new lines in their place. same process for front and rear. if that wont work then you have the wrong lines.
I don't know which thread to respond in, so this is a quote from the other one.
I can't see what your problem is. The braided kit only replaces the 2 rubber hoses, the standard steel hoses remain.
On the front, the block bolts to the upright.
One braided hose (from memory the longer one) goes from the block to the inner guard where it joins the steel tube at the right angle bracket on the inner guard.
The other braided hose (from memory the shorter one) goes from the block to the joint for the steel tube that goes to the calliper.
On the rear, the block end of the braided hose bolts to the steel hose that goes to the calliper.
The other end of the braided hose joins the steel tube at the right angle bracket on the inner guard .
Cheers
Gary
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
