I still can't really believe I'm writing this, but I turned up at the end of work today to the car park to find my loan car (courtesy of Doyles) has been flogged. Full tank of fuel too.
If anyone see's a white '89 EA Fairmont registration UYU 678 (& Doyle crash advertisement) please call the cops.
Thanks
https://www.sau.com.au/forums/topic/218223-broken-into-and-stolen/
Already thought of that. Had it planned to get some. Now I wish I'd had them already!
Bit of a worry 2 times it a fortnight, almost wonder if it's the same guy, which if the cops had done their f*@%ing job would have been locked up by now.
I'm going to be causing a major storm at work tomorrow too believe me!
mikes got insurence on all the cars so i dont think he's going to have too unless theres an excess as mike doesnt charge for loan cars :s
hopefully you would have dug into the cops abit after this happening to you again plus your work should probably get some cameras up to catch these people!
sucks man! remember though, it comes in 3's :D
heavy duty chain wrapped in rubber + heavy duty padlock = cheap wheel clamp. i keep one in my boot should i find myself parking in an area i dont trust, wrap it through the wheel spokes and around the strut.
hopefully the cops actually do something this time around.
lol i like the chain idea just dont forget about it when ya drive off lol
Sorry to hear Jared, what a pain hey!
i was going to post on here last night, something like; 'i bet there will be some sorta rampage on tonight - robberys/smash n grabs etc"
- and surprise suprise, reports of an overnight crime spree on the radio this morning! Probably had nothing to do with this particular car - but anything's possible eh!
Not in my car, but I've had that embarassment on my bike with a brake disc lock. :banana:
Sux to hear about the "loan" car being stolen ... thats just f**king stupid. :ermm:
My old man received a phone call at home from the Cops tonight. The Loaner was found a burnt out shell, no doubt after being used to commit some sought of criminal act.
As far as insurance goes, yes Mike does loan them out to customers for free, but there is a $500 excess I will have to cover + I've lost several hundred dollars worth of clothing etc. that was in the car (from staying at the girlfriends).
Whatever I take to work now (if I decide to keep working in said shit hole) is going to be an excessively secured shitbox so no one bothers touching it
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
